RG2550 Low E string tuning issue - Jemsite
post #1 of 6 (permalink) Old 03-28-2015, 10:50 AM Thread Starter
I have been playing my 2550 a lot this past week, but I noticed something odd:
I had changed the strings awhile ago, and swiftly put it in the hardcase (I was busy playing my Carvin and Roadcore). I took out the 2550 to play and my tuning was a bit off. I did lots of stretching and now all the strings are fine, even when I pull back on the trem arm.. .except the low E string. It goes out of tune REALLY easily, and no matter how much I use the arm, the tuning isn't stable at all. I did lots of pulling on the arm to help stretch the strings, then I did 1.5-2 semitone bends to get more stretch going on, but it still goes way out of tune.
What are some possible issues that I can check and eliminate one by one until I find the cause of this issue?
MatiasTolkki is offline
post #2 of 6 (permalink) Old 03-28-2015, 11:07 AM
Re: RG2550 Low E string tuning issue
- Loose nut pad bolt
- Loose saddle string bolt
- Loose saddle intonation bolt
- Inadequate stretching
- Different brand/type of strings
how to check some of the above :
Strum the strings in their headstock part. Completely dive the trem and keep it there. Strum again. Do you see any change in any string? If yes, then the nut pads need tightening.
Do you feel the saddle moving towards the neck side? Measure exactly and measure again. Tighten if needed.
panix is offline
post #3 of 6 (permalink) Old 03-28-2015, 12:11 PM
RGTFanatic's Avatar
These guitars had problematic nut pads. After many string changes or locking/unlocking of the pad the string would start making a groove in the pad itself. This allows the string to slip even without any use. Check the pads and the nut for any grooves/wear. You MAY have to replace it.
RGTFanatic is offline
post #4 of 6 (permalink) Old 03-28-2015, 02:11 PM
^^^ or coat pads and nut top with a thin layer of liquid metal epoxy at least where the grooves might have developed. In case this is the problem.
panix is offline
post #5 of 6 (permalink) Old 03-28-2015, 07:33 PM Thread Starter
Where can I find metal epoxy? I'll check the issue tonight and see what I can figure out.
post #6 of 6 (permalink) Old 03-28-2015, 08:56 PM Thread Starter
I checked the pad, some wear but not enough to cause tuning instability.
The screws on the front of the bridge that lock down the saddles were somewhat loose, tightened all of them nice and snug.
I had then forgotten that I had raised my action on this particular guitar and forgot the lock the EZ down again. Also did that. I didn't play it yet but I will when I get some time to make sure those were the only issues that may be causing the instability. I'll post an update later. Thanks panix and RGT
JS1200 Tuning Issue SatchMo' Ibanez JEM, UV, JS & Other Signature Models 8 04-14-2013 10:55 AM
hello (and question about tuning issue following set up) requiem156 Tech: Setup, Repairs and Mods 3 10-19-2012 04:42 PM
RG350MDX tuning issue. NEED HELP Stemb0 Tech: Setup, Repairs and Mods 3 10-16-2012 06:29 AM
Trem tuning issue? MT01 Tech: Setup, Repairs and Mods 9 08-17-2008 12:02 PM
Tuning issue psp777 Tech: Setup, Repairs and Mods 12 01-31-2008 07:26 PM
