RG270DX replacement tremolo? - Jemsite
post #1 of 10 (permalink) Old 02-03-2012, 07:31 AM Thread Starter
I have a late 90s RG270DX that has served me well for many years despite being a lower end guitar. It has a no name single locking trem though which I'd like to swap out. Does anyone know which trems fit it with minimal modification to the face of the guitar?
Also I've been told that this trem may accept standard OFR saddles on the original plate. The knife edges are still in near perfect condition so if that is a possibility I'm willing to look at that as well.
gideond is offline
post #2 of 10 (permalink) Old 02-03-2012, 05:26 PM
Reviews: 120
Re: RG270DX replacement tremolo?
Get a Gotoh licensed Floyd Rose, install the locking studs and anchors that cOme with it and don't look back.
LonePhantom is offline
post #3 of 10 (permalink) Old 02-03-2012, 08:32 PM Thread Starter
That's the plan really, I'm just looking for minimal routing on the surface. I just installed a Gotoh for a friend a few months ago. I'll have to get his guitar back over here and take some measurements.
gideond is offline
post #4 of 10 (permalink) Old 02-05-2012, 09:36 PM
The single locking tremolo on these usually accepts original floyd rose tremolos and variants and ive put these on before. You may wish to go with a gotoh variant as they are similar in build quality to the higher end edge tremolo systems
sniperfrommars1 is offline
post #5 of 10 (permalink) Old 03-01-2012, 11:04 AM
I replaced the original trem with a Lo Trs2 trem, but I had to cut out 2mm for each side of the tremolo cavity. If you use a cutter, maybe you don't need to repaint the top of the guitar but you have to be very carefully!
mikorm is offline
post #6 of 10 (permalink) Old 03-01-2012, 11:35 AM
I had the same trem, i replaced the saddles with string saver ones, and set it to dive only. I could not get great floating action with the lower end unit, but in dive only it is great. This was a 60ish dollar option, but I believe cheaper saddles can be had.
andrewgosline is offline
post #7 of 10 (permalink) Old 03-01-2012, 10:18 PM Thread Starter
I think I'm going to end up with a Gotoh 1996 in it. Right now I'm putting it on the back burner. I have an old Silvertone 1484 waiting for a rebuilt. I've never worked on an amp before so this will be a new one for me. I know enough to drain the caps so I don't electrocute myself but that's about it.
gideond is offline
post #8 of 10 (permalink) Old 04-01-2012, 10:33 PM Thread Starter
Well, I changed my mind. I decided not to drop $180 on a Gotoh 1996 for a guitar of this quality. Instead I went ahead and put about $32 into turning the existing single locking tremolo into a double locking tremolo. It turned out pretty well. It was a nice project to do in lieu of another tremolo swap.
Original
New Saddles
Rebuilt Tremolo
Back in action
Full details of the work done are at my blog if anyone needs the info.
http://gideond.wordpress.com/2012/04...ade-for-cheap/
Thanks for all the input.
gideond is offline
post #9 of 10 (permalink) Old 04-02-2012, 04:52 AM
Good choice! Cheap and succesfull!
mikorm is offline
post #10 of 10 (permalink) Old 04-02-2012, 06:48 AM Thread Starter
Yeah but I wouldn't recommend it for anyone who used the tremolo a lot, which I personally don't. I don't feel that the knife edges would be hard enough to hold up to frequent use.
gideond is offline
ofr , rg270dx , tremolo
Edge3 Replacement Tremolo (no mod-free upgrade except EdgePro) digitalsubstance Tech: Setup, Repairs and Mods 397 02-15-2020 02:09 AM
Replacement tremolo Dimebagjimi Tech: Setup, Repairs and Mods 2 02-01-2012 10:58 AM
RG470 Tremolo replacement? sheepshagger101 All Other Guitars (including Prestige) 3 08-26-2010 01:16 PM
ZR tremolo arm replacement FrostStorm Tech: Setup, Repairs and Mods 5 03-08-2010 02:02 PM
tremolo replacement callen3615 All Other Guitars (including Prestige) 4 11-08-2008 12:41 AM
