RG321 neck - Jemsite
post #1 of 10 (permalink) Old 05-03-2005, 06:06 PM Thread Starter
RG321 neck
okey.
MetalVoivod is offline
post #2 of 10 (permalink) Old 05-03-2005, 09:43 PM
Re: RG321 neck
Is the guitar still playing fine?
Could be the fretboard coming slightly unglued from the neck, or some of the wood being stripped by the neck screws.
Globbits is offline
post #3 of 10 (permalink) Old 05-03-2005, 11:57 PM
Re: RG321 neck
Sometimes the fretboard glue gets in between the truss rod slot, truss rod, and fretboard. So you year a cracking sound on new necks until everything regains motion again and the glue bond is broken. Even after that, sometimes the glue rubs against the truss rod so you still hear that noise. You can hear it a lot when you give a new guitar it's first truss rod adjustment too. Inspect it for any cracks at all the glue joint lines and if there's nothing, then it's probably fine.
frankfalbo is offline
post #4 of 10 (permalink) Old 05-04-2005, 12:10 AM
Re: RG321 neck
Watch out for cracks in the back of the neck around the headstock, among other places.
ryanb is offline
post #5 of 10 (permalink) Old 05-04-2005, 12:18 AM
Re: RG321 neck
It could just be the sound of the wood binding with the screws. I wouldn't worry about it. But don't bend your neck anymore
I have the same guitar, but in the Mahogany Oil finish. I love it! I wouldn't mind getting it routed for a Lo Pro though. The height adjustment screws on the saddles bug me to death, I can't stand them when I have to rest my hand on the bridge.
tone_connoisseur is offline
post #6 of 10 (permalink) Old 05-04-2005, 12:35 AM
Re: RG321 neck
I had a similar problem with a hard-tail bridge on a 421.
The tops of the heigh adjustment screw would shread the side of my hand.
You can get shorter set-screws or shim the neck enough to raise the saddles off the bridge a little.
I did the latter and everything is fine.
old_metal_head is offline
post #7 of 10 (permalink) Old 05-04-2005, 03:21 AM Thread Starter
Re: RG321 neck
thanks guys
post #8 of 10 (permalink) Old 05-04-2005, 11:31 AM
Re: RG321 neck
You could send it back and just mention that it has the fret buzz and you'd like a replacement. Or just take it to a good guitar repair guy and have him check it out. He can atleast make sure that you have the proper trussrod adjustment and set it up the way that you want. And have him check out the neck too, just to make sure.
post #9 of 10 (permalink) Old 05-04-2005, 03:31 PM
Lightbulb Re: RG321 neck
Yeah, it'd definitely be less of a hassle to just have a professional look at it before you consider sending it back. It could just be something small that you've overlooked. I know when I got my RG370DX it had some bad fret buzz but the guy at the store adjusted the truss rod and that got rid of MOST of it. But later, I took the locks off the neck so that I could stretch the strings and back out the fine tuners and after that the fret buzz completely disappeared.
lyconxero is offline
post #10 of 10 (permalink) Old 05-04-2005, 04:36 PM Thread Starter
Re: RG321 neck
well.
fret buzz , guitar tech , maple neck , neck joint , neck screws , rod adjustment , truss rod , truss rod adjustment
FS Ibanez RG321 Fretless (with extra neck) supergirl20_06 Classified Ads: Guitars and Gear 2 12-02-2009 11:14 AM
Dislike the neck on my rg321 cmaj7#11 All Other Guitars (including Prestige) 4 06-25-2008 02:29 AM
Wzard neck on an RG321 body cjl5150 All Other Guitars (including Prestige) 17 05-11-2008 12:57 AM
What's the neck joint type on the RG321? toneboy All Other Guitars (including Prestige) 5 06-24-2006 06:36 PM
