RG560 restoration (aka hackjob) - Jemsite
post #1 of 26 (permalink) Old 05-24-2013, 11:48 AM Thread Starter
Hi all. First any input/suggestions appreciated.
What follows below is my first attempt at refinishing a guitar. I bought an old square heel RG 560 a year or so ago for a couple hundred bucks. Has a little fret wear and the original owner had a local guitar shop cut the front route to take a humbucker. So essentially tried to convert it to a 570. The color was still the factory finish, but there were some chips in the finish with exposed wood. I was going to repaint it and just try to epoxy in the holes where the chips had occured.
However after pulling the electronics I found that the 'luthier" who had done the original mod had simply freehanded the route. The hole was all "wonky" (crooked) and one of the pickup rings screws didn't actually do anything more than make contact on one side.
Mskrad is offline
post #2 of 26 (permalink) Old 05-24-2013, 11:53 AM Thread Starter
Re: RG560 restoration (aka hackjob)
SOOOO. Not wanting to keep it simple and just repaint it, I did the first stupid thing I could think of and grabbed a heat gun and removed the finish (After wasting 2 cans of aircraft stripper in a futile attempt to remove the factory clear). The picture in the first post shows me about halfway through removing it....and yes those are scorch marks. Luckily they were very superficial and sanded out with minimal effort.
Then I got really stupid and decided, with my limited knowledge of woodworking, to try to "repair' the original route and take it back to a HSS configuration. I probably should have bought a template and filled the entire thing in and rerouted it. What I did instead was to grab a piece of basswood and use a jigsaw to cut a piece to fit into the hole like this.....
Mskrad is offline
post #3 of 26 (permalink) Old 05-24-2013, 11:55 AM Thread Starter
Finished sanding (which I don't have pics of) and epoxied in a few small dings, skimmed and then primed.
You can see that the "fixed" piece isn't as smooth as I could have preferred. In fact I'm not sure if I really improved anything, but either way its done now.
Mskrad is offline
post #4 of 26 (permalink) Old 05-24-2013, 12:06 PM Thread Starter
So I decided to do a variation/tribute to the LNG. I've shot some HOK for a bike I did, but I decided just to use a rattle can for this since I'm trying not to sink any more money than I have to for my first try. I found some stuff called Liquitex which is an acrylic polyurethane. Sprays much easier than most rattlecan I've used before. No globs of paint getting thrown around and no issues with drips. It does have a fairly fine spray head (but they actually sell a pack to change the shape of the spray if you are so inclined. ) Dries pretty darn fast.
Mskrad is offline
post #5 of 26 (permalink) Old 05-24-2013, 12:21 PM Thread Starter
Another couple of coats (this stuff goes on very thin..but very evenly)
Also, in the process of attemtping to use paint stripper, I unintentionally removed the shielding paint. so Instead of trying to reapply it, I'm going to use copper backed foil tape to shield the cavities.
Current status: I sanded the paint to 600 (probably unnecessary), then reapplied several more coats. This weekend I'm going to apply the shielding tape/copper to all of the routes/cavities. I bought some Eastwood 2K clearcoat that I plan to use when the weather turns a little better around here.
In the meantime I've got to find some pink pickups and some yellow knobs. If anyone has a single source for these I would appreciate any recommendations. I'm probably going to put an EVO 2 in the Bridge and a PG injector in the neck. Still not sure what do do with the middle pickup. Again, any recommendations would be appreciated.
I was tempted to have the fretboard reinlaid (livewire seems to do nice work) with pyramids, but Figure I'll wait until I see how the end result of this current project is before I tackle that. If it turns out like crap, at least I haven't sunk that much money into it.
I'll post more pictures as this progresses.
Mskrad is offline
post #6 of 26 (permalink) Old 05-24-2013, 01:22 PM
Very cool.ill be watching the progress
Boombatty is offline
post #7 of 26 (permalink) Old 05-24-2013, 03:28 PM
Green! My favorite color for a guitar. I can't wait to see it when it is finished.
November5th is offline
post #8 of 26 (permalink) Old 05-24-2013, 05:08 PM Thread Starter
Clear coat was delivered today. If I can get the cavities shielded tonight I should be able to get it cleared tomorrow ( if the weather holds). Otherwise it will be next week. Supposed to rain Sunday -wed
Mskrad is offline
post #9 of 26 (permalink) Old 05-25-2013, 03:23 PM Thread Starter
This is a pain in the butt to do. Still have a few areas that need to be touched up. When the temperature, rain and humidity cooperate, the clear will go on.
Mskrad is offline
post #10 of 26 (permalink) Old 05-25-2013, 03:46 PM
RGTFanatic's Avatar
Nice work M......... this is a project after my own heart
Make sure you paint the pickup cavities black. You don't want to see the copper tape when the pups are installed.
RGTFanatic is offline
post #11 of 26 (permalink) Old 05-25-2013, 05:02 PM Thread Starter
Good point. I was considering painting them neon pink or yellow but that may be overdoing it a bit
Mskrad is offline
post #12 of 26 (permalink) Old 05-25-2013, 05:15 PM
Reviews: 13
When I saw the first pic in this thread I was wondering where this was going tp go and was a little worried . However you have managed to recover well. I look forward to seeing how this rolls out.
-Wolfram
Wolfram is offline
post #13 of 26 (permalink) Old 05-28-2013, 08:58 AM Thread Starter
Well apparently we are having a monsoon season in mid Missouri this year so looks like it may be a week or two before it is dry enough to shoot the clear
Mskrad is offline
post #14 of 26 (permalink) Old 05-28-2013, 09:36 AM
-Wolfram
+1 nice job sir!
GUITARMAGEDDON is offline
post #15 of 26 (permalink) Old 06-08-2013, 09:10 PM
Did you used E-poxy ti fill the humbucker space and make it a single coil again?
I may need to do that on a AANJ neck pocket.
Scarified_pr is offline
rg refinish
My Jem FP restoration IbanezFreak777 Tech: Setup, Repairs and Mods 25 05-21-2013 10:43 AM
The Ultimate DY Restoration Verus Ibanez JEM, UV, JS & Other Signature Models 63 11-25-2012 05:02 PM
My DY Restoration Jeminizer Ibanez JEM, UV, JS & Other Signature Models 72 01-02-2011 06:59 PM
Amp restoration reguv760 Gear, Equipment, Recording & Off Topic 1 05-21-2003 07:12 PM
FrankenJEM - ...the restoration Mark DY Ibanez JEM, UV, JS & Other Signature Models 19 04-27-2002 02:09 PM
