RG570 edge trem post body crack - Jemsite
post #1 of 6 (permalink) Old 07-14-2013, 05:30 AM Thread Starter
Hi
I have had a go at wicking super glue into a hairline crack on my RG570 (pics hopefully attached)
The crack goes from the trem post insert to the tremolo rout and is around 12mm deep. I was able to remove the insert and get at the crack from inside the post hole. The glue (CA pink/fine) mostly dribbled outside the crack instead of sucking into it like I had hoped.
My options now seem to be:
The good: Take it to a pro mender
The bad: Reinstall trem and hope for the best
The ugly: Try and sand back the finish on the tremolo rout side of the crack and wick glue in from the other side.
Any thoughts/opinions on what to do next please? I was getting advice from a local repair guy but he is out of action for a bit so the project has stalled.
Jim
jimdeathhand is offline
post #2 of 6 (permalink) Old 07-14-2013, 10:32 AM
RGTFanatic's Avatar
Re: RG570 edge trem post body crack
option 3 is the one I would take.
I would use a SMALL flat blade screwdriver to scrape away as little finish as possible to expose the crack. Lay the body in a position that will allow gravity to help wick the CA in. After it's dry, a little fingernail polish over the repair will have it looking fine.
On a side note, it looks like some of the knurling from the anchor has been destroyed. I would double check that the anchor doesn't have any play to it when installed.
RGTFanatic is offline
post #3 of 6 (permalink) Old 07-14-2013, 05:41 PM Thread Starter
Thanks RGTFanatic for your insight. I will have to try and build up the post wall, probably with thicker super glue and sanding dust if the insert ends up with a little play on it. If it really wobbles and the hole needs filling with dowel and re-drilling I'll probably take it to a pro.
Just gotta get the stones together to scrape off the paint and get a good look at the rest of this darned crack. My gf will no doubt enjoy colour matching nail varnish to cover it up once its repaired
post #4 of 6 (permalink) Old 07-17-2013, 06:39 AM Thread Starter
Hi again,
I've had a 'crack' at glueing from the other side and it went ok, but its slightly messy on the top when I went shaky.
As it happens it looked as though quite a bit of glue from the first application did seep all the way through, although the crack still wicked in a little more this time around.
Even though the repair is no longer going to be invisible I am happy that I've got as much glue as possible into the hairline crack so cheers again RGTFanatic
I am unlikely to have time to cover the repair before my summer hols so will upload finished photo another time.
Latest pic attached , I had to delete one of the first pics to make upload room for it.
Jim
post #5 of 6 (permalink) Old 08-17-2013, 05:28 AM Thread Starter
Update:
When the bridge insert went back in after repair the crack opened up again and a new crack also formed next to it. Am totally gutted, will likely have to look for an RG body now.
James
post #6 of 6 (permalink) Old 08-17-2013, 06:05 AM
SYL
Send it to Mick Johnson - he will fix it and you will not even know it ever happened.
SYL is offline
rg;repair;crack;edge;glue
How can I check whether my RG2570 body takes an Edge Pro or Edge Zero trem? JayCartay All Other Guitars (including Prestige) 6 11-18-2012 06:23 PM
WTB Feeler Two Post Trem Strat Body CosmicDebris Classified Ads: Guitars and Gear 0 07-03-2012 10:25 PM
WTB: edge trem post/ trem arm Severinsteelsmith Classified Ads: Guitars and Gear 0 09-20-2010 11:06 PM
RG570, loose trem post stud insert leclaw All Other Guitars (including Prestige) 0 02-18-2006 09:46 PM
Worrying development re: my RG570's Edge trem Fink Floyd Tech: Setup, Repairs and Mods 1 07-06-2004 01:23 PM
