RG7620 feels REALLY stiff... my 9's feel like 10's! Help! - Jemsite
post #1 of 9 (permalink) Old 09-14-2011, 12:49 AM Thread Starter
I have no clue what could be going on here, but my RG7620 feels really, really stiff.... compared to my 7421's and my other 7620, it is a big difference.
The guitar isn't set up differently from my other ones; 9-56 strings, nearly straight neck (and if anything, this neck may be a little more straight than my others), nut height is pretty much identical to my favorite 7421.... the action may be slightly higher than my others, but not by much.
the guitar has the lo pro edge 7 bridge, but it is blocked. my other guitarist played it and noticed the difference right away, and agreed that it felt like the guitar has 10's on it instead of 9's. Bending is noticeably tougher all over the board, and it feels harder to push down on the first few frets of the guitar.
if anyone has any clues to what it could be, please help!
HumanFuseBen is offline
post #2 of 9 (permalink) Old 09-14-2011, 01:16 AM
Reviews: 98
Re: RG7620 feels REALLY stiff... my 9's feel like 10's! Help!
http://www.ibanezrules.com/tech/setup/stiff.htm
AlaskaBat is offline
post #3 of 9 (permalink) Old 09-14-2011, 01:24 AM Thread Starter
well, the only thing is, its blocked both ways (trem can neither dive nor pull up), so that stuff shouldn't matter, right?
post #4 of 9 (permalink) Old 09-14-2011, 01:28 AM
Reviews: 11
Check and make sure the angle on the trem is parallel to the body....
linuxpenguin is offline
post #5 of 9 (permalink) Old 09-14-2011, 08:42 AM
There is a different feel to the guitar,between a blocked and non blocked trem.period
Death.by.G-string is offline
post #6 of 9 (permalink) Old 09-14-2011, 10:34 AM
Reviews: 98
That would explain why it feels stiff.
post #7 of 9 (permalink) Old 09-14-2011, 12:50 PM Thread Starter
huh, so you're saying that i should block it to where the trem can only be dive-bombed, then? i can try that. will that make it difficult to change tunings? my band uses drop A and standard tunings.
post #8 of 9 (permalink) Old 09-14-2011, 01:03 PM
Thats why we all want (and need) +500 guitars right!
post #9 of 9 (permalink) Old 09-14-2011, 05:15 PM
Reviews: 120
If you are only blocking the pull-up you should be fine with tunings.
LonePhantom is offline
it looks so wrong.....but it feels so right. mrjakob69 All Other Guitars (including Prestige) 34 01-20-2009 01:50 PM
bad set up feels good? mrjakob69 All Other Guitars (including Prestige) 3 09-04-2008 09:14 PM
Fretboard feels like... plastic? Davey Tech: Setup, Repairs and Mods 16 03-14-2008 01:03 PM
Which JS feels and sounds best to you? - Which one gets your rikkbeatty Ibanez JEM, UV, JS & Other Signature Models 2 01-22-2002 11:27 AM
Stiff feel - strings feel a tad stiff RSVampire Ibanez JEM, UV, JS & Other Signature Models 1 12-18-2000 12:45 PM
