Rounded truss rod end - is it possible to fix? - Jemsite
 1Likes
  • 1 Post By hako
post #1 of 5 (permalink) Old 09-02-2020, 02:06 PM Thread Starter
Hi!
I have problem with truss rod end in my RG1527. It rounded off after many years despite using original Ibanez tool.
Is it possible to replace just this end of truss rod? If yes - is it easy to do?
ZZelman is offline
post #2 of 5 (permalink) Old 09-02-2020, 05:16 PM
Re: Rounded truss rod end - is it possible to fix?
I think the truss rod looks quite fine... what´s your problem?
Maybe you need to push up the tool a little more to "grab" the rod?
Usually, there is no need to adjust the truss rod if you don´t change the string gauge, so maybe there may be another (neck) issue...?
Algiman likes this.
hako is offline
post #3 of 5 (permalink) Old 09-03-2020, 03:01 AM
All I can se is that trus rod nut should be replaced. It can be 7mm or 8 mm
IBANEZ RULES!! - PARTS FOR SALE
4TRN007MM 7mm
or
4TRN008MM 8mm
I asume it is 7 mm but you can measure.
peromucho7 is offline
post #4 of 5 (permalink) Old 09-03-2020, 04:17 PM
Prestige truss rod nuts are 7mm, it seems it was damaged from improper tools/use? When you use the Ibanez tool there is a really snug/deep fit and you would never damage a nut like that.
BigBazz is offline
post #5 of 5 (permalink) Old 09-03-2020, 04:58 PM
Agree with the other posters, that nut is not rounded, just the very top edge. A properly fitting tool will still work fine.
Algiman is offline
rounded , truss rod
