routing a flush tremolo - Jemsite
post #1 of 4 (permalink) Old 12-14-2009, 05:29 AM Thread Starter
if a trem is flush mounted, could you route some of the body so you could pull up and not have to recess the tremolo
bunghole is offline
post #2 of 4 (permalink) Old 12-14-2009, 07:15 AM
Re: routing a flush tremolo
...yes!
nuno is offline
post #3 of 4 (permalink) Old 12-14-2009, 07:35 AM
No. If you won't want to recess the trem then the only way to get more pull up range is to raise the bridge up which in turn means you need to change the angle of the neck. There needs to space behind the trem one way or another.Even then, pull up range will be constrained by the distance between the front of the trem block and spring cavity so be sure to check that.
toneboy is offline
post #4 of 4 (permalink) Old 12-14-2009, 08:41 AM
that was granted...
nuno is offline
edge , recess , recessed , route , routing floyd
Feeling flush? DavyH Off-topic / Miscellaneous 1 07-16-2009 10:37 AM
Jem routing Vince~ Tech: Setup, Repairs and Mods 8 09-12-2006 07:19 AM
Routing help Andy43 Ibanez JEM, UV, JS & Other Signature Models 3 03-06-2005 01:18 PM
Routing UV? metalmarty Ibanez JEM, UV, JS & Other Signature Models 34 11-28-2002 01:17 PM
Need Help Replacing my Jack - Flush Mount on an American Mas mechanyx Tech: Setup, Repairs and Mods 2 03-24-2002 02:32 AM
