Rusted Stuck Neck Bolt - Jemsite
post #1 of 4 (permalink) Old 07-11-2016, 01:19 PM Thread Starter
Trying to restore an old 1990 S540. My next job is to paint the body. First I need to remove the neck. The neck bolts won't come off. I wish to salvage the neck plate and maybe replace the screws. Any suggestions? I've tried WD40 didn't work. I may need to use a dremel tool and take it out hopefully not in pieces.
Sorry the thumbnail is different image.. but when clicked its correct.
kenmasters is offline
post #2 of 4 (permalink) Old 07-12-2016, 05:59 PM
Reviews: 15
Re: Rusted Stuck Neck Bolt
Doesn't look like you'd be able to salvage that bolt anyway. Just keep going at it with a hammer drill to get it out. Then buy a new one. Seeing that it's deeper than the rest, it might not be an original screw anyway.
lespauled is offline
post #3 of 4 (permalink) Old 07-12-2016, 10:26 PM Thread Starter
Thanks... Yeah I will need to replace the screws... anyone know off hand what screw sizes are?
I will try hammering it a bit to losen it up. I've heard that some people used glue on the screws to help make it sound like a glued on neck. If that's the case I may need to use nail polish or something to remove the glue first. I hope this is not the case.
post #4 of 4 (permalink) Old 07-12-2016, 10:32 PM
site founder 0% owner
jemsite's Avatar
watch the length on the screws if it's the tilt-neck the low-E screws are longer than the high-E screws. Too long and you'll go thru the fretboard.
I would try some heat and dish soap (not oil) to loosen the screw after lightly tapping it. You should have no trouble getting wood screws out but you are damaging the hex the point where you might not easily get it out since it's countersunk in a metal plate. If you can loosen ultimately get a flat head vice-grip on it that will let you remove it as the hex gets wrecked.
jemsite is offline
Ibanez bolt on basswood/bolt on mahogany/neck through KevinMarchesini All Other Guitars (including Prestige) 2 05-12-2012 08:19 PM
Bolt-on VS neck-thru hollow125 Ibanez JEM, UV, JS & Other Signature Models 17 06-09-2007 10:49 PM
My neck is stuck!? shredded All Other Guitars (including Prestige) 1 08-20-2005 01:36 PM
New Neck-Through vs Bolt-On The_Grindfiend Tech: Setup, Repairs and Mods 22 09-06-2004 01:36 AM
stuck on a neck pup AARRGGHHH Pickups & wiring 8 04-15-2003 02:48 PM
