Scratchy volume pot sound - Jemsite
post #1 of 4 (permalink) Old 01-31-2010, 07:53 PM Thread Starter
I seem to have some major scratching sounds when I turn the volume knob. Ideas? Is it the possible grounding mess on the back of the pot perhaps? Should I just try re soldering it?
There are like 9 wires that need to go on that little spot on the back of the pot. Does it matter how they are put on there or anything like that?
Thanks
manofthewild07 is offline
post #2 of 4 (permalink) Old 01-31-2010, 07:55 PM
elcid's Avatar
Re: Scratchy volume pot sound
Replace it.
Are the 8 wires on the lugs or just the back of the pot?
elcid is offline
post #3 of 4 (permalink) Old 01-31-2010, 08:25 PM Thread Starter
Originally Posted by elcid View Post
Replace it.
I used this diagram
http://www.dimarzio.com//media/diagrams/C.pdf
So they're soldered to the back of the pot, but its kinda messy.
I've also read it could be dust in the pot and needs to be blown out, but since I just got the body used and it came with the pots I dont know theyre history.
post #4 of 4 (permalink) Old 02-01-2010, 09:35 PM
elcid's Avatar
You could probably spend $5 on a can of deox to try to clean it and it may fix it, or spend $5 on a new pot and know it will fix it.
elcid is offline
installation , pickups , soldering , volume
jem 7v jem 77v Big sound played at low volume or not ??? dudefellas Ibanez JEM, UV, JS & Other Signature Models 2 11-23-2008 05:33 PM
Scratchy noise pickup selector help dan321 All Other Guitars (including Prestige) 7 11-27-2006 08:23 PM
Scratchy Pick Up Selector Switch chromeboy Tech: Setup, Repairs and Mods 3 02-03-2003 08:09 PM
Scratchy Arm Bar Noises - a bit annoying Scott Smith Archived Topics and Common Questions 10 07-26-2001 01:32 AM
Scratchy Arm Bar Noises - a bit annoying Scott Smith Tech: Setup, Repairs and Mods 9 02-03-2001 10:11 PM
