Screwhole repair please help!!!!!!! - Jemsite
post #1 of 13 (permalink) Old 11-12-2011, 05:26 AM Thread Starter
Unhappy Screwhole repair please help!!!!!!!
the screws (inside the cavity) that hold the claw + the springs of the tremolo bridge to my guitar have come loose in the wood , how can i tighten them up?? the radius of the one of the two springs has increased as the hole has gotten bigger .... right now i cannot tighten the screw inside the hole .....
i have attached this pic ...
as u can see the screw hole on the right side (circled black) has gotten so big that i cannot tighten the screw inside it !!!!
bonsuer is offline
post #2 of 13 (permalink) Old 11-12-2011, 05:31 AM
Re: Screwhole repair please help!!!!!!!
toothpicks and woodglue
jym-ellis is offline
post #3 of 13 (permalink) Old 11-12-2011, 06:59 AM Thread Starter
i need the procedure!!!!!
bonsuer is offline
post #4 of 13 (permalink) Old 11-12-2011, 08:48 AM
Step one: dip toothpick in wood glue.
Step two: stick toothpick in hole.
dcord is offline
post #5 of 13 (permalink) Old 11-12-2011, 11:34 AM
Yep see how many toothpicks seem to fit tight. Then coat them with glue and push them in. You can use a wood chisel, utility knife, razor, etc. to remove what is left protruding from the hole. Let it dry over night and you can screw the claw back in.
gideond is offline
post #6 of 13 (permalink) Old 11-12-2011, 11:48 AM
RGTFanatic's Avatar
Great advice guys. It IS that easy, however I would suggest sinking the screw in as much as possible before the glue dries and let that sit overnight. This way the glue/wood will dry in perfect fitting threads instead of breaking the glue to create new threads
RGTFanatic is offline
post #7 of 13 (permalink) Old 11-12-2011, 01:38 PM
Don't fill the hole entirely, by the way. You still want to leave space for the screw to actually go in. One or two toothpicks should be perfectly fine to make the hole snug without making it too tight to fit a screw in.
GuitarBizarre is offline
post #8 of 13 (permalink) Old 11-12-2011, 05:15 PM
RGTFanatic's Avatar
Good point, depending on the size of the hole. Use common sense here, it doesn't need to be packed tight. Leave enough room for the screw to get in there.
post #9 of 13 (permalink) Old 11-12-2011, 08:01 PM
Nice...I was going to suggest that because that's how I do it. Works very well.
TMatt142 is offline
post #10 of 13 (permalink) Old 11-12-2011, 08:17 PM
Why not use a thicker screw?
sebastian is offline
post #11 of 13 (permalink) Old 11-13-2011, 04:27 AM Thread Starter
thanks everyone!!done with it!!! ...bdw i glued the end of the toothpicks together and then pushed them inside ... will that be ok?? and i used 2 toothpicks
bonsuer is offline
post #12 of 13 (permalink) Old 01-24-2012, 03:41 PM
use match sticks and wood glue Lol
dartvader is offline
post #13 of 13 (permalink) Old 02-14-2012, 12:42 PM
Fingernail file the toothpick into fine shavings and mix with the glue. Use this along with non sawdusted toothpicks. It will hold tighter when you mix the sawdust with the glue.
iloveibanezguitars is offline
bridge , fix , prs , screwhole , tremolo
I got a new job... as a guitar repair man. j.arledge Off-topic / Miscellaneous 14 01-27-2009 08:42 PM
Tv repair??? fractionallz Off-topic / Miscellaneous 6 06-25-2008 10:14 PM
Jem 7BSB Repair! Uriel Tech: Setup, Repairs and Mods 0 06-30-2004 10:42 PM
Need help - repair carlos seo Tech: Setup, Repairs and Mods 1 05-01-2003 09:44 PM
