setting the trem angle...questions - Jemsite
post #1 of 3 (permalink) Old 03-06-2006, 11:48 PM Thread Starter
Hi all...well, I've finally changed a stringe on my RG with an Edge Pro trem....wow, I thought tuning the thing was tricky, but this is something else entirely!...I'm getting the hang of tuning now, but I did bust a new string by tightening the screw at the bridge a hair too tight...my bad, but I had enough slack to restring the same string and the day was saved.
And now I've noticed the trem angle is up even a lil more than it was before (which was still a lil higher than it should have been). I've been to the ibanez rules website, but can't seem to get a good handle on this adjustment.
Is it simple to do?...as far as I can tell, you just screw the two claws in the back a quarter turn each at a time time the trem angle is near neutral....but wouldn't that neccesitate retuning the guitar again, which might raise the trem angle yet again?...I ask because I can tune my guitar now, but the trem angle is high when it's finally tuned nicely...I've tried detuning the low E to the point where the trem angle is quite below neutral but by the time I've tuned up, I back to the higher than neutral angle that I started with. I know I'm a noob at floating trems so I know it's a time in thing....can't wait to get better and faster at it!
The main prob with having the trem angle high is that now the trem bar rubs against the volume knob when I swing it out of the way...so I've gotta bite the bullet and adjust the angle myself.
Any tips? Links? Pics? Thanks!
atarilovesyou is offline
post #2 of 3 (permalink) Old 03-07-2006, 03:06 AM
Re: setting the trem angle...questions
look in the tech section at ibanez rules (banner above).
Regards
Andr
fettouhi is offline
post #3 of 3 (permalink) Old 03-07-2006, 03:39 AM
As Andre says go thru the Ibanezrules tech section in detail.
But basically, yes, when you adjsut the spring claw you need to re-tune. When you screw in the claw to reduce the trem angle the strings will go sharp. It will take several iterations to get it spot on.
Once you've set it you shouldn't need to adjust it again unless you change string gauge. Don't forget to change strings one at a time otherwise you'll lose the float point. If you do take all strings off then block the trem at a neutral angle
markg5150 is offline
edge pro trem , floating trems
Questions about setting up low action Alpha_AI All Other Guitars (including Prestige) 1 11-13-2009 05:48 AM
Questions about setting up my Edge Pro trem billyboy Tech: Setup, Repairs and Mods 7 04-05-2006 08:55 PM
setting the angle... Adagio_777 Tech: Setup, Repairs and Mods 7 05-18-2005 08:05 PM
Setting up Edge Pro angle rrhea Tech: Setup, Repairs and Mods 3 05-15-2004 11:02 AM
Setting Trmeleo angle 6StringGod Tech: Setup, Repairs and Mods 9 09-27-2003 02:18 AM
