shimming the neck - Jemsite
post #1 of 6 (permalink) Old 02-22-2004, 09:26 PM Thread Starter
shimming the neck
hello.........i have a new ibanez 1570 lefty.........upon buying it from american musical supply.......it had no fret buzz anywhere....
But the tremelo seemed to me set high...........the pickups are mounted to the wood body........the tremelo was so high in fact that when i put dimarzio pickpups in it and used the stock foam pads under the pickup by the time i got the pickup high enough to the strings it ran out of compresion from the foam pad..so the pickups would flop.......
after reading the great info here on shimming the neck...i decided to try and do this to mine.........as i noticed at the neck joint the neck it self had a sharp decline in slope comparing it to the top of the body that is........anyways i lowered my tremolo so that the front part near the studs barley sticks above the cavity maybe a 1/8th inch this apears to me to be about the height that the bridge should be set at..........
i took a piece of cardboard and placed it under the back side of my trem to keep it raised and then i took my front neck screws out and placed a piece of credit card inside.......after a few trys i got where i wanted it......
the shim ended up in the center of the neck pocket.........there no buzz anywhere i can play every fret on the low E string no buzz.........
is this commen for others having to shim there necks????
does the tremelo being about a 1/8th inch about the body at the studs sound about right?? thanks for your time
honky_tonk is offline
post #2 of 6 (permalink) Old 02-22-2004, 10:43 PM
To get a perfect fourth of pullup with low action 99% will need a neck shim. A busness card is usually more than needed, credit card only if it's called for. Too much neck angle, strings too far off the body, bridge too high, or at least much more than is necessary
Rich is offline
post #3 of 6 (permalink) Old 02-22-2004, 11:40 PM
if the guitar plays well now, and to your liking, I'd say you did the right thing.
The Madness Here is offline
post #4 of 6 (permalink) Old 02-23-2004, 04:43 PM Thread Starter
thanks guys.........its seems to play just as good as before but now the neck doesnt nose dive in the pocket about a quarter of a inch like it did before..........
and my tremelo is almost flush with the top of the body.....so im happy........kinda makes me mad that it being a prestege neck it was like this though.....
post #5 of 6 (permalink) Old 02-23-2004, 05:43 PM
"Prestige" just points to neck "finishing", has nothing to do with how well it wasn't setup at the factory
Rich is offline
post #6 of 6 (permalink) Old 03-08-2004, 10:19 PM
I have a pair of 1570L's now. The DiMarzio's are taller than the V7/V8's. I routed the floor of the pickup cavity under the pickup ears only. Mine bolt up with no shims. My guitars had too much shim under the nut though (.020") , a .005" shim worked well.
Dr_Guitar is offline
fret buzz , neck angle , neck joint , neck screws , neck shim , pickup cavity
first time neck shimming chrisrivas1 Tech: Setup, Repairs and Mods 13 02-10-2011 06:48 PM
What Exactly Is Neck Shimming? JeffWiredBeck24 Tech: Setup, Repairs and Mods 28 07-25-2008 06:33 PM
Shimming neck angle.... Rotti Tech: Setup, Repairs and Mods 6 12-28-2005 02:48 PM
neck shimming moby All Other Guitars (including Prestige) 2 01-02-2005 06:41 AM
shimming neck johank Tech: Setup, Repairs and Mods 5 10-27-2002 09:18 PM
