Shocking Pink Paint? - Jemsite
post #1 of 17 (permalink) Old 06-20-2004, 11:03 AM Thread Starter
Has anybody gone to the trouble of finding a "Shocking Pink" paint? Is there a paint from PPG or Dupont, etc. that's a close approximation to the original Ibanez color? If so, do you know the code (Kenneth)?
I don't have a guitar that's SK, so I can't have it matched. That'd be to easy!
TAorama is offline
post #2 of 17 (permalink) Old 06-20-2004, 08:46 PM
www.houseofkolor.com
The original supplier of all the Ibanez neon paint.
Cheers,
Butch
butch is offline
post #3 of 17 (permalink) Old 06-21-2004, 10:56 PM Thread Starter
Well hey, that was easy. Thanks!
TAorama is offline
post #4 of 17 (permalink) Old 08-12-2004, 12:30 PM Thread Starter
In looking at HOK's spec sheet for their Neon Pink paint, it says that it's UV sensitive. I assume that's why all so many SK's fade? Is there any way to prevent that if I'm painting a new axe using the HOK color? Seems silly to use a paint I know won't retain it's color. Not that I'll be playing at the beach much...
TAorama is offline
post #5 of 17 (permalink) Old 08-12-2004, 02:01 PM
Well as long as you're not using it on a UV........Haaaaahahahaaawoohoo!
frankfalbo is offline
post #6 of 17 (permalink) Old 08-14-2004, 08:05 PM Thread Starter
I can't believe you actually posted that.... Thought it yes - actually posted it? Terrible!
TAorama is offline
post #7 of 17 (permalink) Old 08-17-2004, 09:09 AM
The Neon paints that I have used always have carried that UV warning. I had an 88' SK that hadn't faded at all when I got rid of it in 94'. I used to take that thing out in the sun all the time
I used to use auto wax on it, back then because I worked at a Detailing Shop and it was free. Not sure if that helped it or what. Best of luck.
Distantshore is offline
post #8 of 17 (permalink) Old 08-20-2004, 09:37 PM
I think i have a brilliant idea to prevent neon colors from fading....a rather obvious one that is.......USE SUN BLOCK!!!!! all over the guitar, make you sure you don't use too much 'cause then it'll cover up the finish and be pointless. If you judge correctly, you should have a protective layer of sunblock that'll protect your guitar from harmful UV rays!!!
bobojem is offline
post #9 of 17 (permalink) Old 08-20-2004, 11:02 PM
Just a safety note, the HOK paints are automotive urethanes, they are isocyanides and absolutely MUST be sprayed in a proper booth with proper respirators and paint suits. The HOK neon concentrates have to mix with HOK or another 2 pack urethane clear.
This is not paint to mess around with, it is incredibly toxic. It is also quite expensive and the neons are not easy to spray, specifically pink, it has the worst coverage of all the neon's.
Just my $.02
littlegreenman is offline
post #10 of 17 (permalink) Old 08-21-2004, 04:07 PM Thread Starter
Well, that explains what happened to my short term memory.
Well, that explains - wait... what's the topic?
Hey, has anyone used HOK neon pink?
TAorama is offline
post #11 of 17 (permalink) Old 08-23-2004, 12:59 PM
LOL,
yes, I have used it, in fact I have a quart of it in my shop as we speak, along with a quart of LNG. Like I said though, you have to mix it with clear, it's very difficult to spray evenly and it's deadly.
There is a neon pink from Createx that matches perfectly too and it's water based, but you still have to clear coat it with something.
post #12 of 17 (permalink) Old 08-23-2004, 07:02 PM Thread Starter
Maybe I'll go the Createx route. Clearing shouldn't be a problem - I've done that before, at least. Thanks for the tip. I'm all for using stuff that won't kill me or make my buy more safety gear.
TAorama is offline
post #13 of 17 (permalink) Old 08-23-2004, 09:45 PM
Originally Posted by littlegreenman
LOL,
Hmmm... That quart of LNG paint wouldn't happen to be what's going to be used for ...uh... a certain Jemsite Forum member's guitar..., would it?
whatshisname is offline
post #14 of 17 (permalink) Old 09-09-2004, 08:29 PM Thread Starter
Regarding the Createx paint, will it take a "conventional" polyurethane clear and have enough adhesion to the guitar not to cause problems down the line? From the info on the website, it looks like it's more of a water-base fabric/craft paint than something that would hold up well on a guitar.
TAorama is offline
post #15 of 17 (permalink) Old 09-09-2004, 08:50 PM Thread Starter
Nevermind. I was looking at the www.createx.com site. What I was really looking for was www.autoaircolors.com. Looks like just the trick! Heh.
TAorama is offline
clear coat
1987 Neon Pink (Shocking Pink) RG550 w/hsc 80z?ubet! Classified Ads: Guitars and Gear 7 03-19-2012 05:49 PM
SHOCKING PINK brianxtr Ibanez JEM, UV, JS & Other Signature Models 37 11-30-2009 02:31 PM
Anyone know where to get shocking pink paint to touch up my jem smurfdaddydog Ibanez JEM, UV, JS & Other Signature Models 42 11-19-2006 04:07 PM
looking for shocking pink jem serranasweep Classified Ads: Ibanez JEM/UV Guitars 7 12-10-2005 02:31 AM
WTB: Shocking Pink Jem tonymeoli Classified Ads: Ibanez JEM/UV Guitars 0 03-02-2005 05:00 PM
