small stress crack near bridge anchors. am I in trouble? - Jemsite
post #1 of 10 (permalink) Old 11-05-2011, 08:03 PM Thread Starter
I was pressing in the anchors for the bridge on my new Ibanez body and one went it fine, while the other made a tiny tick noise and I knew exactly what it was.
I have this small fracture now and it worries me. Do you think this will still hold fine? It has a tung oil finish, will that interfere with glue?
If not, what can I do?
Thanks
Ridealot100 is offline
post #2 of 10 (permalink) Old 11-06-2011, 12:11 AM
Reviews: 98
Re: small stress crack near bridge anchors. am I in trouble?
Looks like an area that won't be visible when complete. If you can, remove the bushing and shoot some glue into the crack. Let dry, sand it, then insert the bushing again.
AlaskaBat is offline
post #3 of 10 (permalink) Old 11-06-2011, 06:35 AM
Bat has it correct!
Jamm'n Jimmy is offline
post #4 of 10 (permalink) Old 11-06-2011, 06:40 AM
Looks like the hole was drilled a litle small for the ancher and it pushed the wood apart.
Some pieces of wood are just dryer or harder than others. As long as it doesn't spread over time, it is no big deal. If it does spread, it will crack the finish near it.
sebastian is offline
post #5 of 10 (permalink) Old 11-06-2011, 09:08 AM
PCG
With the bushing installed, I would carefully wick CA glue into the crack to neutralise any further cracking.
PCG is offline
post #6 of 10 (permalink) Old 11-06-2011, 10:58 AM
Take a look at this one.
It's evidently been like that since the guitar was bought as we never realized it. No problems have resulted so far. I might get around to filling it one of these days. We put new studs in as well and still no issues. This is a basswood body.
gideond is offline
post #7 of 10 (permalink) Old 11-06-2011, 12:52 PM Thread Starter
you guys have given me hope! It is at the guitar techs shop right now getting a special glue injected into the crack.
post #8 of 10 (permalink) Old 11-06-2011, 05:05 PM
RGTFanatic's Avatar
It sounds like your tech is goint to use the CA that PCG suggested. That's good insurance for the future.
RGTFanatic is offline
post #9 of 10 (permalink) Old 11-06-2011, 05:15 PM
So many opinions.
Personally,i would keep the bush in there,and use a 2-part-epoxy,something like 'Araldite'.
The reason would be is that its quite flexible,and will flex with the body,as it contorts under pressure.And expands when placing the Trem Screw back in in.
Taking the bush out would serve no major advantage,other than when the compound has fully cured,placing the bush back in may stretch the crack open again.
Looks fairly minor,so either way u cant go wrong,but personally i would keep the bush in.
Cheers.
ozjem is offline
post #10 of 10 (permalink) Old 11-06-2011, 07:26 PM Thread Starter
from my understanding, me and the tech agreed that we would glue it with the post in because I don't plan on every pulling them out.
And if we ever have too, we can always pop it loose with heat.
Thanks for all of the input guys. really appreciate it
crack , ibanez
Brand New Jem 77FP Stress Crack in neck joint Trev Ibanez JEM, UV, JS & Other Signature Models 63 04-06-2019 12:20 AM
Small crack in neck m0p Tech: Setup, Repairs and Mods 5 09-11-2006 08:56 AM
Stress crack on neck joint, or just a finish crack? m0p Tech: Setup, Repairs and Mods 6 11-09-2005 05:59 PM
Stress Crack on my 8670 kennydoe All Other Guitars (including Prestige) 25 09-08-2005 10:22 AM
Stress crack shredmaster Ibanez JEM, UV, JS & Other Signature Models 40 01-19-2003 10:35 PM
