So a piece of string is stuck in my ZR bridge. - Jemsite
post #1 of 6 (permalink) Old 01-24-2006, 03:11 PM Thread Starter
Angry So a piece of string is stuck in my ZR bridge.
I was restringing my S1625 yesterday, and everything was going fine until I got to the B string.. I loosened the string, then loosened the "block" that holds the string in at the bridge.. but the block didn't come loose, no matter how much I loosened the screw. So I inspected, and I noticed that the string had somehow gotten wedged into the side of the block (even though it's more of a t-shaped thing than a block on ZRs), which immobilized the block. I tried a bunch of tools to try to yank it out, but all that accomplished was severing the exposed string from the part lodged in the block so that I can't do anything now. I hope I explained that clearly enough, I wish I had a camera so I could get some visuals for you. Has this happened to anyone before? If so, how do I fix it (short of buying a whole new saddle, which will set me back 30(!) bucks)? My band is playing a huge show Saturday and I'd like to be able to use this guitar... so any help would be appreciated. Thanks.
ttiwguitar is offline
post #2 of 6 (permalink) Old 01-27-2006, 02:11 PM
Re: So a piece of string is stuck in my ZR bridge.
What i'd do is take out the saddle and see what you can do then, dont panic though, if there is a problem take it back to the place you bought it and get dude 1 to fix it!
regards
Jonny
PacificaJonny is offline
post #3 of 6 (permalink) Old 01-27-2006, 02:14 PM
if you can get at it, why not try a magnet? the string is made of magnetic material and might fly loose.
ChopTart is offline
post #4 of 6 (permalink) Old 01-27-2006, 02:19 PM
Choptart has a good idea, use a strong one. I'd do that. Is there a little bit of the string outside the saddle? If so, use a pair of pliers and a magnet to get it out, also u could try to remove the string block...
post #5 of 6 (permalink) Old 01-27-2006, 02:19 PM
You might try backing the locking screw all the way out and see if you can pull the lock block itself out. If the block won't come out you may be able to move and nudge it around enough to work the string piece loose.
Chroma is offline
post #6 of 6 (permalink) Old 08-23-2010, 10:43 PM
I know this is an old thread, but I just experienced the same problem ttiwguitar had.
I have an Ibanez s5470 Precision with a ZR2 bridge and the G string was wedged in the bridge saddle against the "T" block. I tried jeweler's screwdrivers, etc. to no avail.
Then, I read Chroma's advice, removed the screw completely, then the "T" block snapped back and the string popped out immediately.
It worked great.
- s
subexpression is offline
High E string frets out (Gets stuck) whenever played davester1234 Tech: Setup, Repairs and Mods 9 03-26-2014 10:57 AM
tapping 8 string piece using Axe FX Std daken1134 Gear, Equipment, Recording & Off Topic 1 10-30-2013 11:10 PM
new 8 string piece vibetronic Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 10 02-25-2006 02:41 PM
Stuck on a bridge pickup professor_chaos Pickups & wiring 2 04-23-2003 05:21 PM
String Guages - I'm well stuck in my rut! Devo Ibanez JEM, UV, JS & Other Signature Models 20 06-21-2001 01:17 AM
