Square heel and tilt neck joint differences - Jemsite
post #1 of 7 (permalink) Old 06-16-2018, 09:33 AM Thread Starter
Just wondering if the hardware (screws) that mount the neck to the body of a tilt joint heel RG are different to the ones for the square heel models eg. Pre AANJ RG470.
I'm pretty sure the location of the holes are the same but are the screws different lengths and the heads angled according to the tilt?
Hope this makes sense. Reason I ask is i have a 92 RG470 with a superb neck and am considering a nicer body like an earlier generation Jem or simar vintage RG550+ to attach the neck to.
Julz77 is offline
post #2 of 7 (permalink) Old 06-16-2018, 08:19 PM
Super Moderator
Re: Square heel and tilt neck joint differences
I believe that the treble side screws are shorter, if you use the same length screws on a tilt heel, they’ll come through the fretboard.
I’ve never actually tried the swap you’re about to try, so I don’t know for sure, but take care in case I’m right!
jono is offline
post #3 of 7 (permalink) Old 06-16-2018, 11:30 PM Thread Starter
Cheers Jono. Will look for a tilt heel mounting kit.
Julz77 is offline
post #4 of 7 (permalink) Old 06-16-2018, 11:52 PM
They're the same as an AANJ, back pair become the high side, front are the short ones, they're 35 and 40mm overall length although they've never used near enough screw length as they should.
Rich is offline
post #5 of 7 (permalink) Old 06-17-2018, 05:52 AM Thread Starter
Great info. Just one final question. Apart from the mixed length screws, is there anything else required like special washers, ferrules, neck plate or spacers to ensure the screws go straight up or is the heel tilt angle a non issue?
Julz77 is offline
post #6 of 7 (permalink) Old 06-17-2018, 05:27 PM
Tilt joints are plate joint only.
Rich is offline
post #7 of 7 (permalink) Old 07-13-2018, 10:29 AM Thread Starter
I bought a sweet old RG570 body to replace the emerald green body on my beloved RG470. I also ordered black knobs and pickup rings to give it the full Wesley Snipes treatment. All I need now is those shorter AANJ mounting screws mentioned earlier in the thread and jack cavity cover and I'm in business. Wouldn't mind an Ibanez machined neck plate if I can find one.
File Type: jpg Adobe_20180713_225202_1531488192085.jpg (1.28 MB, 20 views)
File Type: jpg Adobe_20180713_225349_1531488337262.jpg (1.53 MB, 21 views)
Julz77 is offline
WTB: Ibanez RG570 or RG770 body (square heel joint) Dr.StrangeNote Classified Ads: Guitars and Gear 2 03-14-2016 11:29 PM
RG750/760: Cutaway heel or Square heel? mag8 All Other Guitars (including Prestige) 11 01-19-2016 07:43 AM
Square heel or AANJ neck joint? Guitarmattms All Other Guitars (including Prestige) 7 01-24-2012 01:48 AM
WTB a 540PII Body square heel joint IbanezFreak777 Classified Ads: Guitars and Gear 6 01-28-2011 11:56 PM
WTB RG550 square heel joint Shark Tooth Smile Classified Ads: Guitars and Gear 0 04-22-2009 12:58 PM
