Steps to replace the neck? - Jemsite
post #1 of 4 (permalink) Old 04-25-2015, 04:53 PM Thread Starter
I know it's just four bolts, pretty cut n dry, but is Ibanez similar to Fender in the regard that you need to drill out the body holes so that the screws don't bind? I had an old Telecaster once that I replaced the neck on and I ended up having to use an 11/64 drill bit on the body holes to open them up so the screws passed through cleanly. Otherwise, the neck didn't sit flush in the back of the pocket since the screws were binding.
Anyway, considering a neck replacement on an Ibanez but I don't own a drill atm. If I could get by without drilling, that would be awesome.
RG_Freak is offline
post #2 of 4 (permalink) Old 04-25-2015, 06:23 PM
RGTFanatic's Avatar
Re: Steps to replace the neck?
I do the same on most of my bodies. Having the neck screws bind against the body is an all to common problem that's easily avoidable.
RGTFanatic is offline
post #3 of 4 (permalink) Old 04-25-2015, 07:04 PM Thread Starter
Thanks! I'll see if I can borrow a drill from a friend then.
You know, it would be absolutely awesome if these guitar makers would just make the body holes bigger from that start, but I suppose there's a reason for it. To streamline the manufacturing process perhaps?
RG_Freak is offline
post #4 of 4 (permalink) Old 04-26-2015, 10:22 AM
RGTFanatic's Avatar
Like anything, there's a trade-off. When the holes for the neck screws are enlargened there's a better chance to misalign the neck in the pocket. The upside is that there's also more room to re-align a neck in a pocket that may not be perfect.
570 Neck replace? Josh_P Tech: Setup, Repairs and Mods 9 02-23-2011 05:47 AM
Unbound neck to replace bound neck on an S Series? ketiov All Other Guitars (including Prestige) 9 03-09-2009 08:25 PM
Replace Cracked JS100 Neck with Jem neck ggl Ibanez JEM, UV, JS & Other Signature Models 15 12-22-2006 01:03 PM
Replace Jem neck or fix it? keithmoore Ibanez JEM, UV, JS & Other Signature Models 1 11-17-2004 12:16 PM
to replace JEM neck where to get a new one? Jare Ibanez JEM, UV, JS & Other Signature Models 5 05-15-2003 01:18 PM
