string alignment? - Jemsite
post #1 of 5 (permalink) Old 06-29-2011, 04:58 PM Thread Starter
string alignment?
what does it mean that the string alignment in a guitar is off? Is it too hard to fix?
thx
dreamtallica is offline
post #2 of 5 (permalink) Old 06-29-2011, 06:10 PM
Re: string alignment?
you mean the distance between the first/last string and the end of the fingerboard is off?
bancika is offline
post #3 of 5 (permalink) Old 06-29-2011, 06:15 PM Thread Starter
just asking what the term meant dude, cuz I read it somewhere.
Cheers
post #4 of 5 (permalink) Old 06-29-2011, 07:46 PM
Reviews: 34
Cheers
In what context was the phrase used in the article?
Do you mean the strings aligning with each other, the edge of the fret board, the tuning pegs, the pickups?
I can understand the confusion. It is a vague term
nickcoumbe is offline
post #5 of 5 (permalink) Old 06-29-2011, 10:38 PM
Typically it will be the alignment of the strings on the neck, how centered they are. It's easy to fix if the neck pocket will allow the neck to move to where the strings are centered. Plenty of pockets will not, and you need to correct the pocket alignmnet first. Some necks won't want to stay in place even with the screw torque so you can side shim the neck pocket to keep the neck centered even without torque.
Rich is offline
ibanez rg premium , string , string alignment
neck alignment / nut alignment alt12345 Tech: Setup, Repairs and Mods 0 08-20-2009 02:37 AM
string alignment Homebake Tech: Setup, Repairs and Mods 6 12-31-2008 06:30 PM
Bad neck/string alignment: need advice stratoskier Tech: Setup, Repairs and Mods 3 06-19-2005 07:01 PM
String alignment Dazza1004 Tech: Setup, Repairs and Mods 3 05-04-2005 03:05 AM
String Alignment Jeff Tech: Setup, Repairs and Mods 11 11-16-2002 10:48 PM
