String buzz - Jemsite
post #1 of 15 (permalink) Old 11-12-2009, 05:58 PM Thread Starter
String buzz
I've been playing for about a year now and am encountering a problem on my Ibanez that I haven't encountered on other guitars I've owned. Seems that when I play, specifically when I picking notes on a specific string, other strings are vibrating as well causing open notes that I am not meaning to play. Mostly this is happening on the low E string. Is this an indication that my action may be too low? I don't feel as though it is. I'm not getting any fret buzz.
Sportrider24 is offline
post #2 of 15 (permalink) Old 11-12-2009, 06:13 PM
Re: String buzz
Muting other strings while you play is part of your technique which you'll have to develop over time with practice, it's not to do with the guitar. Try using fingers on your fretting hand to mute notes you don't want to ring out, and the picking hand can do a lot as well, particularly for the lower strings.
skins345669 is offline
post #3 of 15 (permalink) Old 11-12-2009, 07:53 PM Thread Starter
Re: String buzz
As an example, if I cover the 9th fret of the G string and pick it a few times the thick E string starts to vibrate causing noise.
post #4 of 15 (permalink) Old 11-12-2009, 11:00 PM
Reviews: 18
Re: String buzz
Do your strings buzz when you pick open notes? If so, you may need to add a shim under the nut to increase open string clearance. Is your action set really low? Can't think of any other reason why your other strings would buzz when they are not being played.
sirshredsalot is offline
post #5 of 15 (permalink) Old 11-13-2009, 09:25 AM Thread Starter
Re: String buzz
Wish I was at home right now to check. If I remember correctly, it doesn't happen when I play an open note (I could be wrong though). I know that 1/2 way down the fret board is when I notice the problem. The action could be set too low. I felt it was set up pretty good from the factory and haven't changed it. I think I will raise the action on the A and E strings and see if that helps. Adding shims seems pretty strait forward. Is there anything I should be careful of (being a noob) if I need to do that?
post #6 of 15 (permalink) Old 11-13-2009, 11:03 AM
Reviews: 59
Re: String buzz
Is the problem that you have string buzz? or that you get a sounding on your low E when you're playing other strings. I've had problems in the past where I'll be playing the intro to Zep's Good Times Bad Times and despite muting the strings I get low E "feedback" or vibration through the amp. Is your problem similar to that?
smooth55 is offline
post #7 of 15 (permalink) Old 11-13-2009, 11:19 AM Thread Starter
Re: String buzz
It's not amp feedback. My thick E string just vibrates when I play other strings causing the amp to pick up that vibration.
post #8 of 15 (permalink) Old 11-13-2009, 11:40 AM
Re: String buzz
Seriously, don't mess around with the action if you're not getting any buzz, try working on your muting technique.
post #9 of 15 (permalink) Old 11-13-2009, 12:04 PM Thread Starter
Re: String buzz
Definatly no fret buzz.
To answer smooths question, I've never played good times, bad times but for grins and giggles, if I were to play the intro to Bon Jovi - wanted dead or alive, an into that does not utilize the low e string, nor do I feel i should have to mute it, the string will vibrate causing a faint and sustaining open note sound through the into. Like I said, it is faint and really isn't too noticable but it is there.
post #10 of 15 (permalink) Old 11-13-2009, 12:18 PM Thread Starter
Re: String buzz
I just thought of something! I mostly use the bridge pickup. One of the poles that sits under the thick E string is out more than the others on this pickup. Could this be causing the problem? Maybe it needs to be lowered to the height of the others? It's the only pole that I notice a difference in height out of all three pickups.
post #11 of 15 (permalink) Old 11-13-2009, 12:35 PM
Re: String buzz
Okay, feel free to lower the pole, but it's in your best interests to work on your muting technique. It will be a huge help when you start playing at slightly louder volumes, with slightly higher gain or with slightly more articulate pickups, which are probably all things you will start to do as you become a better player (don't go crazy on that gain though, it tends to go down as your playing gets better).
post #12 of 15 (permalink) Old 11-13-2009, 12:49 PM Thread Starter
Re: String buzz
Thanks Skins. I'm playing through a Fender Vibro Champ and I have noticed that even on gain settings, as I've improved I have lowered the gain.
I'll try lowering the pole tonight and see if that helps any.
post #13 of 15 (permalink) Old 11-13-2009, 12:53 PM
Re: String buzz
Cool, good luck, let us know!
post #14 of 15 (permalink) Old 11-02-2010, 02:18 PM
Re: String buzz
Its not a problem with the guitar, it's technique as already stated.
musikron is offline
post #15 of 15 (permalink) Old 11-02-2010, 02:38 PM
Reviews: 98
Re: String buzz
The thread is a year old--I'm sure he figured it out long ago...
AlaskaBat is offline
String Buzz on the Low E guitarman13 Tech: Setup, Repairs and Mods 0 06-02-2006 11:57 PM
Need help with string buzz RG_76 Tech: Setup, Repairs and Mods 2 04-17-2005 03:09 PM
String Buzz Reishiman Tech: Setup, Repairs and Mods 10 02-12-2004 04:28 PM
Buzz!! low E string on first 3 frets! Ibanezer Tech: Setup, Repairs and Mods 9 11-06-2003 04:16 PM
can't get rid of string buzz on JS10th SilverSurfer2 Ibanez JEM, UV, JS & Other Signature Models 32 01-13-2003 08:25 AM
