String gauge vs tremolo question - Jemsite
post #1 of 9 (permalink) Old 05-27-2013, 08:01 AM Thread Starter
Smile String gauge vs tremolo question
Hi,
I wonder I would like to try 60-10 for my rg570. Now using 11-50 and need 5 springs there. Using E standard tuning.
One part of my question is about durability of knife edges of my Edge. Should I be worried? Other part is about slipping string from the bridge saddle due big tension. Is here someone who tried that gauge or have recommendation of using or not using such a gauge?
My main goal is to have tight full power chords and thanks to the tension probably very low action. Thanks.
Wakizashis is offline
post #2 of 9 (permalink) Old 05-27-2013, 06:41 PM
Reviews: 120
Re: String gauge vs tremolo question
I don't know that you are going to get any added benefit in terms of tightness going to a 60. It will probably not fit the locking nut very well either.
LonePhantom is offline
post #3 of 9 (permalink) Old 05-27-2013, 07:08 PM
If you want tight sound you should actually focus on brightening the sound not dull it it mud with such thick strings.
try 0.11 stainless steel strings and add bass from an eq, also a compressor might help depending on what you have in mind.
mertay is offline
post #4 of 9 (permalink) Old 05-28-2013, 01:05 AM Thread Starter
Hello,
my point was to make it tight - let me explain. When thin string is strummed, it oscillates in wider and not that ordinary waves. Tighter string oscillates in more ordinary waves (shape) and not that furiously. The result is "tighter" sound. At least for me. Another benefit is possible lower string action because that, but even now my action is very low, so it would lower the buzz when strummed hard.
post #5 of 9 (permalink) Old 05-28-2013, 03:38 AM
Reviews: 120
Seriously, why do you think going to 60s will give you a better response? I doubt it's going to make that much of a difference at the tension E standard will give you, and it may not fit the locking nut properly anyway.
post #6 of 9 (permalink) Old 05-28-2013, 06:24 AM Thread Starter
Hi,
as I mentioned above. Though, if it is dangerous either for nut or neck or bridge, I will ignore that... That was what I was asking for...
post #7 of 9 (permalink) Old 05-28-2013, 06:59 AM
Originally Posted by Wakizashis View Post
Hello,
I agree with the feeling and non-buzzing but not sure if we can apply this to tone. Rather than string, I'm not 100% sure if the pickup can handle it while maintaining its character as most aren't designed for this (except the 8 maybe 7 string pickups, and these pickups actually has reduced sub frequencys to bring the clarity for thick/lower strings).
While experinemting if possible try to record the sound difference. A very common mistake I notice is people confuse the quality of tone when output is increased while comparing. After recording match the levels when judging and if possible share with us too
mertay is offline
post #8 of 9 (permalink) Old 05-28-2013, 06:41 PM
Reviews: 120
Hi,
As I mentioned as well, I don't think it's going to make a big difference in tightness, it will be much of a muchness. I seriously doubt you'd be able to hear it in recordings, other than an overbearing low end, and combine that with the locking nut not being able to lock down properly it's just not worth it.
post #9 of 9 (permalink) Old 05-29-2013, 01:07 AM Thread Starter
Ok, I guess, that kind of gauge is idea for normal nut then. I guess I then try 52 max and won't go further. I would be glad if my nut and bridge would last some while. It is disgustingly expensive here, in Europe and eastern European salaries do not help as well. Thanks for help guys. Appreciating your effort.
10-60 gauge
About zero tremolo and string gauge satchtabber Tech: Setup, Repairs and Mods 5 03-18-2012 07:57 PM
7 String gauge question.... nosferatu123 All Other Guitars (including Prestige) 31 03-19-2011 01:01 PM
String gauge/trem springs question asolid Tech: Setup, Repairs and Mods 3 01-15-2010 02:34 AM
Drop D with 0.12 string gauge on Edge 3 tremolo Yamadron Tech: Setup, Repairs and Mods 3 08-15-2009 07:53 AM
Jem Tuning/String Gauge Question jippy Ibanez JEM, UV, JS & Other Signature Models 2 06-27-2002 07:08 PM
