String retaining bar on headstock - Jemsite
post #1 of 4 (permalink) Old 10-11-2004, 05:49 AM Thread Starter
The headstock string retaining bar (behind the nut) on my Jems seems to be set at different heights, is there a standard setting based on string height ?
Benson is offline
post #2 of 4 (permalink) Old 10-11-2004, 07:09 AM
dex
If you want to minimise how sharp the strings are pulled when you lock the pressure pads - make sure that the retaining bar is set low enough to hold the string down all the way across the nut.
There's no point having it lower than that and having it higher would make the bar redundant.
ilia
dex is offline
post #3 of 4 (permalink) Old 10-11-2004, 07:19 AM Thread Starter
ah, that makes sense, ta.
Benson is offline
post #4 of 4 (permalink) Old 10-11-2004, 09:27 AM
if the truss-rod cover sits on the way and keeps the retainer-bar to be set low enough, pull it out.
nuno is offline
retaining bar , string retaining bar
REQ: Pics of a 12-string IBZ Headstock TAorama All Other Guitars (including Prestige) 6 02-12-2004 07:15 PM
Flo's string retaining bar pri0531 Ibanez JEM, UV, JS & Other Signature Models 43 09-11-2002 09:05 PM
locking nut tuning problem - string retaining bar all the wa utopia Archived Topics and Common Questions 14 10-15-2001 09:55 AM
String retaining bar - Need some help here trouble311 Tech: Setup, Repairs and Mods 7 10-08-2001 09:22 AM
locking nut tuning problem - string retaining bar all the wa utopia Tech: Setup, Repairs and Mods 12 02-16-2001 01:07 AM
