String sticks to pickup - Jemsite
post #1 of 8 (permalink) Old 01-06-2016, 06:45 PM Thread Starter
I've recently purchased a pgm300 and have put new strings on and slightly lowered the action to my usual position. However I find when I dive bomb with the tremolo the low E string sticks to the single coil. I've looked about online for advice on this issue the best I could find is lower your pickup. I have fully lowered the single coil as far as it will go and the string still sticks. Is there any other remedies for this problem than raising my action as I'm very happy with the guitar now apart from this issue.
bear1 is offline
post #2 of 8 (permalink) Old 01-06-2016, 10:33 PM
RGTFanatic's Avatar
Re: String sticks to pickup
Other than using a nylon low-E? Don't dive so deep? It's a steel string sitting on a magnet. It's gonna stick
RGTFanatic is offline
post #3 of 8 (permalink) Old 01-07-2016, 12:30 PM
Yeah, that's 100% normal for doing dives with singlecoil pickups (which tend to have a fair amount more magnetic pull than humbuckers).
You can live with it, which is what most people do, or try to find a singlecoil with less magnetic pull - most hum-cancelling singlecoils will fit this description. Lace pickups have very little magnetic pull, and the Golds are pretty "normal" sounding, and the Dimarzio Area series pickups are excellent and tend to pull less than true singlecoils, too.
Personally, I'd just live with it as part of the "sound" and character of a guitar - every time you've heard someone dive to slack with a guitar with singlecoils, you've heard the "click" of the strings starting to stick to the pickups. It's actually kind of cool, once you open yourself to embracing it.
Drew is offline
post #4 of 8 (permalink) Old 01-07-2016, 01:07 PM Thread Starter
Thanks for the replies I have an rg with a hum cancelling pickup in and haven't had the problem. Nor was I expecting it as guitarists like Vai super dive bomb and don't seem to have their string stick. I won't be pulling any pickups out as the pgm in question was once toured and played by Mr Big himself. Rgt when u say nylon strings do you mean like acoustic nylon strings?!
By the looks of it I'll just have not bomb so deep and get used to it. Any other guitar I would deffo pickup swap tho.
bear1 is offline
post #5 of 8 (permalink) Old 01-07-2016, 01:13 PM
During installation of new strings, after putting end of string in bridge, bend them slightly upward between bridge humbucker and middle pickup. Bend them slightly. When you tune guitar you would not feel string bend, but when you dive tremolo bend should show up an lift strings away from single coil, if you place it properly.
peromucho7 is offline
post #6 of 8 (permalink) Old 01-07-2016, 02:08 PM Thread Starter
What do you use to bend the string between the pickups? Just your hands when your pre stretching your strings?
bear1 is offline
post #7 of 8 (permalink) Old 01-07-2016, 02:35 PM
I bend it with fingers, after I put one end of string in bridge , and before I put other one in tuner. You need just minimal force. If you bend it to hard, string will have small curve or belly even in full tension. You do not want that. You just want string to "remember '' shape when you slack it and move away from single coil. I originally start to do that to force string to move in such shape to track bridge humbucker to maintain deep sound on deep dives.
post #8 of 8 (permalink) Old 01-09-2016, 11:12 AM Thread Starter
Its a great idea that I'll try next i restring my guitar
bear1 is offline
WTB: 7 String Pickup Speedabob Classified Ads: Guitars and Gear 3 09-24-2011 03:19 PM
Ibanez ZR sticks out the back of my guitar =S CTravaglini Tech: Setup, Repairs and Mods 2 02-25-2011 11:35 AM
7-STRING PICKUP HELP _LeviathaN_ Pickups & wiring 4 11-30-2008 05:52 PM
Floorball sticks... The Euphor Off-topic / Miscellaneous 4 12-29-2006 02:18 PM
The best 7 string pickup microdmitry All Other Guitars (including Prestige) 9 02-05-2003 11:25 PM
