String tension and how to convert stringsize? question - Jemsite
post #1 of 6 (permalink) Old 01-24-2013, 06:18 PM Thread Starter
I have my JEM7VL-WH neck set up by RICH for tuning in D (DGCFAD) with D'addariostrings EXL 110 (010-046).
I will be doing a couple of concerts where the guitars will be tuned in standard E and I wonder if it's possible to use other size of strings that gives the neck about the same tension as I have when the guitar is tuned to D while using D'Addario EXL 110s?
The reason for NOT wanting to adjust the neckrelief as Rich has set the neck up just fantastic and I dont want to loose that amazing setup
freewheeler is offline
post #2 of 6 (permalink) Old 01-24-2013, 07:02 PM
Re: String tension and how to convert stringsize? question
there is some info out there on string tension. I think d'addario has lists info and i know for a fact it has been posted here on the jemsite forums. so do a search
as far as messing up your guitar(neck and relief go) i wouldn't worry too much about the neck, your trem wont be set up right and neither will your intonation. The guitar itself wont be messed up though.
j.arledge is offline
post #3 of 6 (permalink) Old 01-24-2013, 07:03 PM
Change to 009-042. in E to keep the same tuning.
Your intonation might be slightly off,but tension will be the same so no tremspring or strussrod asjusment needed.
(in both tunings the stringtension will be about 60 kilograms)
Death.by.G-string is offline
post #4 of 6 (permalink) Old 01-24-2013, 07:06 PM
edit: change to 009-042.in E to keep the same tension
post #5 of 6 (permalink) Old 01-24-2013, 08:40 PM
Truss rod is not a permanent adjustment and needs to be checked and adjusted anytime the environment changes. Just make note of where you like the relief, and you can always return it to that spot.
Rich is offline
post #6 of 6 (permalink) Old 01-24-2013, 09:45 PM
Reviews: 37
Smile Re: String tension and how to convert stringsize? question
yeah man work those trussrods dont be scared.
funny that people do so much to avoid so little.
there is 5,000,000,000,000 tutorials on trussrod adj.
i use my trussrod like a tuner.
andrewsfury is offline
d'addario , jem 7v neck , relief , string tension
Question about String Tension! abstract_noise Tech: Setup, Repairs and Mods 10 01-24-2012 08:55 PM
random question. String tension linuxpenguin Tech: Setup, Repairs and Mods 3 03-03-2011 05:42 AM
string tension and spring tension choubix Tech: Setup, Repairs and Mods 4 06-11-2007 03:21 PM
String tension question: Roland All Other Guitars (including Prestige) 9 09-23-2006 05:47 AM
String tension, noob question no1spretty All Other Guitars (including Prestige) 15 06-02-2006 05:04 AM
