Strings problem - Jemsite
post #1 of 2 (permalink) Old 12-11-2009, 05:26 PM Thread Starter
Strings problem
Hi my name is sebastian and i just changed the strings on my ibanez jem from 9 gauge to 10 and the tremolo angle just wont get lower (to being parallel to the body as it should). I have an edge pro tremolo and the manual says i have to tighten the screws in the back (spring cavity) but the two screws are tightened to max. Do i have to get another spring or should i change the springs positions?
hope somebody can give me advice on this, salutes.
sebotas86 is offline
post #2 of 2 (permalink) Old 12-11-2009, 05:50 PM
Re: Strings problem
Yeah, either adding a spring or rearranging the ones you currently have are your only options really. How are your springs configured now? Probably wouldn't even hurt to replace the ones you have. Check the link and scroll all the way to the bottom. He lists some spring configurations according to string gauge.
http://www.ibanezrules.com/tech/setup/angle.htm
cornstar70 is offline
tremolo angle
Am I the only one that thinks DR Strings uses colors to cover poor quality strings? Clonetool Tech: Setup, Repairs and Mods 37 07-19-2007 02:58 PM
Fret Buzz problem, lower 3 strings only. SidewinderINC Tech: Setup, Repairs and Mods 6 04-02-2006 03:12 PM
Wierd Lo-Pro Edge 7 problem... big problem! Jupiter Tech: Setup, Repairs and Mods 5 06-11-2003 01:43 PM
So here's my Problem: - I snap strings at the bridge everyda davester1234 Ibanez JEM, UV, JS & Other Signature Models 15 04-05-2002 07:19 PM
UV777BK trem problem - I think it is a problem (shrug) Scoff X Tech: Setup, Repairs and Mods 5 09-21-2001 12:59 AM
