Stuck locking stud - Jemsite
post #1 of 10 (permalink) Old 01-28-2010, 03:37 AM Thread Starter
Reviews: 12
Stuck locking stud
how do I "nudge" the locking screw that's pretty much stuck in the stud? I tried my best using a 1.5mm allen wrench [with the stud removed from the insert] but afraid the wrench might break from too much force... Would a 1.5mm wrench with a larger grip work better? I also tried WD-40 but that somewhat nudged just a tiny bit... do i give this a WD-40 bath?
reguv760 is offline
post #2 of 10 (permalink) Old 01-28-2010, 03:45 AM
Re: Stuck locking stud
Hi, try immersing the stud for a day or so and if you have a 1,5 mm wrench with a larger grip try using it, I'm almost sure once it starts moving it'll be ok. Good luck,
Regards,
Nelson
nsabino is offline
post #3 of 10 (permalink) Old 01-28-2010, 03:49 AM
It does not come out the top, if that's what you're trying
Rich is offline
post #4 of 10 (permalink) Old 01-28-2010, 04:01 AM Thread Starter
Reviews: 12
Rich: no.. i need to move it downwards... it's out just a tiny bit [kinda like a bad zit] but it's stuck and won't budge!
i'll give it a bath and see what happens from there
reguv760 is offline
post #5 of 10 (permalink) Old 01-28-2010, 04:37 AM
heat it up with a soldering iron.
moonlight is offline
post #6 of 10 (permalink) Old 01-28-2010, 04:43 PM Thread Starter
Reviews: 12
very interesting! that would suggest there's some sort of adhesive stuck in there and by heating it up, would "melt" such adhesive... won't the paint "melt" if i heat it up though?
I tried the WD-40 bath and still didn't budge, soldering iron it is.
Don't have a 1.5mm wrench with larger grip... might have to go shopping for those later :P
Reg
reguv760 is offline
post #7 of 10 (permalink) Old 01-28-2010, 05:13 PM
Reg
No, it suggests that heat makes things, particularly metals, expand. Heat up the surrounding threads, they expand and release the currently clenched grub screw. Same principle as putting a bottle top you can't open under hot water.
GuitarBizarre is offline
post #8 of 10 (permalink) Old 01-28-2010, 06:39 PM Thread Starter
Reviews: 12
soldering iron's a success, didn't have to get an extra wrench! thanks guys
Reg
reguv760 is offline
post #9 of 10 (permalink) Old 01-29-2010, 10:09 AM
Glad to hear it, I was going to say heat is your friend for stuck threads!!!! Prolly some rust/laquer/crap in there, and heat usually fixes it.
My immediate feeling is the hot water on bottle top method doesn't necessarily expand the steel bottle top much, more like it softens the rubber gasket and softens any sugar/food/goo that's dried in the threads. I should look up the coefficient of expansion for steel, though.
andrewgosline is offline
post #10 of 10 (permalink) Old 02-11-2010, 08:45 PM
Actually the hot water trick works for almost any stuck lid. Glass with metal lid, plastic with plastic lid, anything, it all comes apart easier under hot water.
locking studs , stuck
Locking stud Axayacatl All Other Guitars (including Prestige) 5 05-23-2008 05:23 PM
Locking stud mod kpinks All Other Guitars (including Prestige) 7 04-10-2006 01:25 PM
Locking Stud Mod!!! KrazyKris24 Tech: Setup, Repairs and Mods 14 12-21-2005 11:48 PM
DIY Locking Stud Mod Shakma!! Tech: Setup, Repairs and Mods 4 11-10-2004 10:35 PM
1527 Locking Stud / Locking Stud Mod Societysucks All Other Guitars (including Prestige) 1 07-05-2004 10:26 PM
