SV54070 nut material - Jemsite
post #1 of 4 (permalink) Old 12-17-2011, 11:36 PM Thread Starter
taracatac's Avatar
Does anyone know what the nut on an SV5470 is made from? Is it plastic, or something similar to a Tusq nut?
taracatac is offline
post #2 of 4 (permalink) Old 12-18-2011, 11:22 AM
Re: SV54070 nut material
FYI, Tusq is just a fancy way of saying "polymer" which is a fancy way of saying plastic.
musikron is offline
post #3 of 4 (permalink) Old 12-18-2011, 11:25 AM Thread Starter
taracatac's Avatar
LOL, good to know. I think it is plastic, and I would like to change it out.
post #4 of 4 (permalink) Old 12-18-2011, 05:13 PM
...No it isn't.
"A polymer is a large molecule (macromolecule) composed of repeating structural units. These subunits are typically connected by covalent chemical bonds. Although the term polymer is sometimes taken to refer to plastics, it actually encompasses a large class comprising both natural and synthetic materials with a wide variety of properties."
Here's a good video explaining what a nut is and does, properly.
http://www.youtube.com/watch?v=ybyrB...eature=related
At the end of the day, if you want more tuning stability, or if your at-the-nut action is too low, then you might want a new nut. If your guitar stays in tune already, and it probably does, as Ibanez tend to have straight string pull, then you probably won't see any significant change in your tone. or playability by getting a new nut.
That is, unless you're moving to an extreme. If you get a brass nut it will be brighter and sustain longer, a wooden nut, the exact opposite. Bone nuts are traditional, but as noted in the video, they're variable and there is good and bad. You can get a plastic nut that sounds better than a bone nut no problem, you just have to cut the plastic nut right and pick out a bone nut with a mediocre cut and soft leading edge.
GuitarBizarre is offline
nut , prestige , s540 , saber , sabre
What material is the EDGE PRO II? STYLO Ibanez JEM, UV, JS & Other Signature Models 4 09-15-2006 08:04 AM
New material Rab Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 0 04-30-2006 05:53 PM
Nut shim...Any material? burt777 Tech: Setup, Repairs and Mods 13 08-02-2003 01:30 AM
Is it the material, or the year? IbanezPrestigeBoy All Other Guitars (including Prestige) 3 07-28-2003 04:02 AM
New Material to learn??!? Swirly Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 4 02-04-2003 01:12 AM
