Swap E and B saddles? - Jemsite
post #1 of 6 (permalink) Old 09-05-2012, 07:08 AM Thread Starter
Looking down my Ibanez 7 string with a floating trem. I can see (what seems to me) a very large height difference between my low B and my low E string. The low B string sits 1mm LOWER than the E at the saddle.
I understand that each saddle on a trem is a different height to match fretboard radius. But could swapping my low b and low e saddles be beneficial?
Could doing this be detrimental in any way or does it sound like a good idea?
Curtis08ltd is offline
post #2 of 6 (permalink) Old 09-05-2012, 09:24 AM
Reviews: 120
Re: Swap E and B saddles?
The Edge type tremolo baseplates are staggered, and the saddles are all the same height. Probably won't get any difference.
LonePhantom is offline
post #3 of 6 (permalink) Old 09-05-2012, 09:26 AM Thread Starter
Thankyou for this thats a helpful response! So perhaps actually shimming the B saddle would be the way to go to get it raised? x
post #4 of 6 (permalink) Old 09-05-2012, 09:56 AM
Contributor
sebastian's Avatar
You can get saddle shims to raise them up.
sebastian is offline
post #5 of 6 (permalink) Old 09-05-2012, 07:02 PM
Reviews: 120
Definitely shim if you feel the need to raise it. Don't waste money on buying shims though. Make some from an old soft drink can, sand paper can work quite well too. I use emery paper to make my shims.
post #6 of 6 (permalink) Old 09-06-2012, 07:55 AM Thread Starter
Cheers for the good responses guys! I appreciate the help
action , bridge , height , saddles
Edge saddles sssteve72 Tech: Setup, Repairs and Mods 1 11-28-2011 09:37 AM
js 1200ca saddles prswrecker Ibanez JEM, UV, JS & Other Signature Models 6 08-05-2008 10:20 AM
Lo-TRS II Saddles suzumebachi Tech: Setup, Repairs and Mods 1 02-14-2006 12:48 AM
Edge Saddles Are All The Same, Right? CrossingStar Tech: Setup, Repairs and Mods 5 07-24-2005 03:08 PM
help with trem saddles!!! rgtojem Tech: Setup, Repairs and Mods 1 10-16-2004 10:17 AM
