Swapping out an edge 3 - Jemsite
post #1 of 6 (permalink) Old 11-22-2010, 12:01 PM Thread Starter
Reviews: 5
Well, I have an Ibanez Edge 8. Great instrument, I like everything about it, from the platinum blond finish to the pickups and the coil tapping options. But one thing must change: the edge 3 is a terrible tremolo system. The gold is fading off it, it refuses to stay in tune, and you cannot pull back on it without the truss rod creeking. I'm tired of applying maintance to it; it must go. My question is would I be able to swap it out for an Original Edge or Edge Pro without having to do any additional routing?
EXshad is offline
post #2 of 6 (permalink) Old 11-22-2010, 12:23 PM
Re: Swapping out an edge 3
Take a look: http://www.jemsite.com/forums/f21/ed...edge+3+tremolo
You should be able to swap the Edge III with an Edge Pro without doing any routing. The same goes for Original Floyd Rose.
Andrius is offline
post #3 of 6 (permalink) Old 11-22-2010, 01:51 PM
Reviews: 10
I have a Jem7vwh with an Original Edge and I can confirm for you that the Original Edge did not fit into the Edge Pro routing so I suspect that you will likely have to do some work to swap the Edge III with an Original Edge. Some dremmel work was required on the body of my Jem7vwh and a little filing was done on the corners of the bridge to make it fit properly. Here is alink to some photos - there is a close up of the bridge:
http://s831.photobucket.com/albums/z...nez%20Jem7vwh/
doriangrey is offline
post #4 of 6 (permalink) Old 11-22-2010, 01:58 PM
Reviews: 7
The edge pro is a drop-in replacement for the edge 3 (you don't have to mod anything to get it to fit in)
Timbaline is offline
post #5 of 6 (permalink) Old 11-23-2010, 12:04 PM Thread Starter
Reviews: 5
My bad... should have seen the big sticky'd topic
With that said, I might getone in black hardware, but how does it stack up in quality and tuning stability? Just curious
EXshad is offline
post #6 of 6 (permalink) Old 11-23-2010, 12:11 PM
Reviews: 98
It's an excellent trem--one of the best!
AlaskaBat is offline
trem replacement edge
Some quick questions about swapping to an Edge Pro.. hotwax1989 Tech: Setup, Repairs and Mods 5 09-21-2009 02:36 PM
Edge swapping Vaibanez Tech: Setup, Repairs and Mods 1 07-29-2009 04:12 PM
Lo-TRS II ??? - swapping with an Edge and more wulpul Archived Topics and Common Questions 16 01-07-2006 08:25 PM
swapping lo pro for edge original adamcbest All Other Guitars (including Prestige) 4 11-10-2004 01:34 PM
swapping EP/EP II with original edge stratman219 Tech: Setup, Repairs and Mods 3 04-28-2003 01:28 AM
