To those who have built an electic guitar (not assembled one) - Double-neck question. - Jemsite
post #1 of 5 (permalink) Old 11-22-2009, 11:22 PM Thread Starter
I have decided that I want to make an electric guitar. It will be my 2nd one. The 1st one I did when I was 15.
This time I want to build/cut/glue/sand/assemble all of it, including the neck.
And I have decided that i want to build a double neck with 12-string.
And i have a design in mind that makes the the 2 headstocks join, and become one.
A daunting task i know for a 2nd time build, but I think I can do it.
But now I have a question regarding double-neck electrics;
When I googled double-neck guitars, 97% of them come back in the standard independent and seperate neck configuration.
Very few of them joined.
Can anyone tell me why (other than the obvious extra precision work involved) I WOULDNT want to try something like this?
I have a design in mind that I like, but I figured I would ask the experts here first...
Thanks -
Trfsrfr is offline
post #2 of 5 (permalink) Old 11-23-2009, 04:07 AM
Jaden's Avatar
Re: To those who have built an electic guitar (not assembled one) - Double-neck quest
I would make seperate necks for so many reasons, too much to type.
Jaden is offline
post #3 of 5 (permalink) Old 11-23-2009, 04:43 AM
If you really want the necks joined then maybe consider use a *bridging* piece of wood attached to both headstocks in some way, that way you can remove it to access each neck separately if you need to, in my experience (I've had 3) they can be neck heavy and adding weight to the headstocks won't help. I like the idea, but I think it will be impractical as I doubt the necks will be sufficiently identical and you may need to adjust them differently.
Jim
Vim Fuego is offline
post #4 of 5 (permalink) Old 11-23-2009, 02:09 PM Thread Starter
I have a really cool design in mind, with a really cool 3 dimensional headstock shape.
I thought it would be neat to join it all together.
I also thought it may help with sustain and tone.
Trfsrfr is offline
post #5 of 5 (permalink) Old 11-23-2009, 02:23 PM
Search up Auerswald guitars. They have a wooden beam connection neck and heastock. Some of the other crazy abominations from the 80's do that too.
Main reason? It doesn't DO anything except make an already neckheavy instrument even more neckheavy. And percieved increases in sustain due to a system like that would be exactly that - percieved. You'd get more extra sustain from using a thicker neck profile, a denser material, or just flat out making the thing better. Heres a hint btw, volutes are GREAT THINGS. Just because older ibanez dont have them doesnt negate that. They REALLY help, not just instrength but also in curbing excess vibration in the headstock, and making the string/neck interface more secure. It increases sustain!
GuitarBizarre is offline
build , double-neck
Noob Question for those of you that have built one Vs. a Real one Mindcore Ibanez JEM, UV, JS & Other Signature Models 8 06-16-2009 08:31 PM
Pre-assembled ibanez pickgaurds?? AmazinAzian12 Tech: Setup, Repairs and Mods 2 05-25-2008 02:45 PM
Built up own Guitar! Manu Tech: Setup, Repairs and Mods 6 09-26-2002 11:24 AM
NEW UZ GUITAR - another has been built !!!!!! swig Ibanez JEM, UV, JS & Other Signature Models 28 07-09-2001 07:37 AM
Custom built guitar question - ... compared to a DNA dacmo All Other Guitars (including Prestige) 2 02-22-2001 01:49 AM
