Trem is acting wierd - Jemsite
post #1 of 3 (permalink) Old 11-27-2005, 05:28 PM Thread Starter
If I pull back, it returns, and if I push down, it returns, but each way leaves it more in that direction if you know what I mean. It doesn't return to the exact same position each time. So if I pulled back on the bar for instance, it would go back leaving the strings a little sharp, and if I pushed down on the bar, it would go back but leaving the strings a little flat, only slightly, but it is something that needs addressing. The trem is a lo-pro. What do you think could be the problem? The knife edges need sharpening?
Pikaciao is offline
post #2 of 3 (permalink) Old 11-27-2005, 05:53 PM
Re: Trem is acting wierd
Your problem will be here
http://www.ibanezrules.com/tech/setu..._stability.htm
most probably #3
Rich is offline
post #3 of 3 (permalink) Old 11-28-2005, 08:25 PM Thread Starter
Still doing it. I'll take it to a techie
Pikaciao is offline
Humbucker acting up? CoBHC Pickups & wiring 2 03-20-2014 07:57 AM
Tone pot acting like a volume pot... RGFREAK Tech: Setup, Repairs and Mods 6 05-09-2011 11:38 PM
Vid: Acting Dumb newbieguitarmaker Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 0 01-16-2009 10:42 PM
Wierd trem noise thc303 Tech: Setup, Repairs and Mods 2 12-01-2003 08:19 PM
Problems with my pickup? Help. - These things are acting wei cghurl01 Tech: Setup, Repairs and Mods 5 03-01-2002 08:32 PM
