Trem arm tension - Jemsite
post #1 of 3 (permalink) Old 01-30-2010, 09:56 AM Thread Starter
Trem arm tension
Bought a RG1550 Prestige with an Edge Pro. Trem works great except the arm swings too freely. I like the tensions set so that I can release the bar and it will stay where it is left. Tried replacing the teflon washers-( I call 'em bushings) and tightening the screw at the base of the arm receptacle (on the underside of the trem base) with no success. Any suggestions?
jsv555 is offline
post #2 of 3 (permalink) Old 01-30-2010, 02:09 PM
Reviews: 11
Re: Trem arm tension
Trem arm mod worked for me, mate.. I just bought a Schaller Trem arm with the install socket, and put it in.. It did take a LITTLE bit of filing on the threads of the baseplate and I had to cut off some of that "cup" (don't know what it's called ) that goes under the baseplate on schallers, but when I got it in, I was a happy camper. And now my flutters are better than ever on ibanez.. Almost as good as ofr.. almost. I think it's the mass and material of the ofr that makes it flutter so good.
FrostStorm is offline
post #3 of 3 (permalink) Old 01-31-2010, 03:10 AM
I recently installed a Schaller arm in a couple of gotoh trems I have. Much better to be able to adjust the arm tension with a quick twist of the nut. Sometimes I like the arm to swing free and others times I like it to stay put. It's also a lot easier to remove when putting the guitar in a case.
moonlight is offline
bushings too small?
string tension and spring tension choubix Tech: Setup, Repairs and Mods 4 06-11-2007 03:21 PM
Blocking the Trem, Does it Affect String Tension? SixStringShredder Tech: Setup, Repairs and Mods 9 09-27-2006 10:07 AM
Please advise on EdgeProII (555) trem arm tension jemoctave Tech: Setup, Repairs and Mods 0 01-24-2005 05:51 PM
Adding spring tension on trem... Dr Mindcrime Tech: Setup, Repairs and Mods 6 09-26-2004 12:00 PM
Jem7v floating Trem Tension SlickXQ Tech: Setup, Repairs and Mods 7 07-04-2003 10:51 PM
