Trem Claw Maxed Out - Jemsite
post #1 of 12 (permalink) Old 12-16-2009, 04:52 AM Thread Starter
Trem Claw Maxed Out
I'm trying to setup a J custom guitar to the best of my ability (still a beginner at this) and ran into a bit of a problem, so I'm hoping someone might be able to help me. It has a Lo Pro trem. I changed the strings to 10s today, and when I tuned it up to standard E, the bridge was pushing very far forward. I went to the screw the trem claw back to compensate for this, but it was already essentially maxed out, so I couldn't do much with it. I pushed it back as far as possible, but now it's maxed out with the screws basically completely into the wood. Unfortunately, the bridge is still leaning pretty far forward. What can I do to work this out so that I can use 10s and level out the bridge? Thanks for any and all help!
ModernGuitarist is offline
post #2 of 12 (permalink) Old 12-16-2009, 04:59 AM
Re: Trem Claw Maxed Out
How many springs are you using? It's still in tune although you already maxed out the trem claw movement?
Brambram is offline
post #3 of 12 (permalink) Old 12-16-2009, 05:01 AM
axemanrio's Avatar
I use 10's too, and what I do with my guitars is add a fourth spring.
axemanrio is offline
post #4 of 12 (permalink) Old 12-16-2009, 06:00 AM
New spring, as many will say, is probably the best answer.
skins345669 is offline
post #5 of 12 (permalink) Old 12-16-2009, 06:35 AM
before you ask, to add a fourth spring you can hook it to one of the spring-lock screw holes, while keeping the other screw in place:
nuno is offline
post #6 of 12 (permalink) Old 12-16-2009, 07:08 AM
You can also try and place two springs diagonally, like this /|\ before you decide to buy new springs.
Brambram is offline
post #7 of 12 (permalink) Old 12-16-2009, 09:42 AM
The arrow pattern has worked for me with 10's in E standard... in the past. /|\
S-man is offline
post #8 of 12 (permalink) Old 12-16-2009, 10:36 AM
Reviews: 5
Talking Re: Trem Claw Maxed Out
+1
E std w/9s = | | |
E std w/10s = / | \
E std w/11s = || ||
I just take the lock down thingy off, never had a spring fly off (I don't get TOO crazy) - symmetry is more important to me, lol
mrclean77 is offline
post #9 of 12 (permalink) Old 12-16-2009, 12:37 PM
axemanrio's Avatar
As well, new guitars don't have an issue with 10's - it's the 10+ year old guitars that seem to need new springs or an additional spring. For my '87 RG, new springs did not help much and I ended up adding a fourth spring (on the bass side, not on the treble side).
post #10 of 12 (permalink) Old 12-16-2009, 01:35 PM Thread Starter
Thanks everyone! Funny how I didn't even consider the arrow style configuration. I'm going to try that today and I'll update to let you know how it works out. I was confused because in the past I've been able to use 10s in E tuning on Ibanez bridges before without any real problems, but this one seems particularly difficult. If the arrow doesn't work, hopefully the spring will.
post #11 of 12 (permalink) Old 12-16-2009, 08:41 PM
Take out the springs for 24 hours. Try them again, and if they do the same thing it might be time to get new springs.
bluffalo is offline
post #12 of 12 (permalink) Old 12-17-2009, 02:08 AM Thread Starter
Just a quick update here. The arrow configuration didn't quite work, alas. However, I added a fourth spring (had an old one laying around) and that did the trick. Many thanks for your help, everyone! It seems to be in good shape now. Cheers!
trem claw screw holes? andrewsfury Tech: Setup, Repairs and Mods 3 10-31-2009 09:34 PM
Trem claw screw issues. CaptainD00M Tech: Setup, Repairs and Mods 8 01-23-2008 08:04 PM
Trem Claw Screw Ripped Out 3.50 Tech: Setup, Repairs and Mods 7 02-14-2007 09:12 PM
WTB trem spring claw. nightfiend14 Classified Ads: Guitars and Gear 4 07-28-2006 01:56 AM
trem claw screws tightened all the way...but I need more davester1234 Tech: Setup, Repairs and Mods 26 04-24-2004 05:05 AM
