trem claw screws tightened all the way...but I need more - Jemsite
post #1 of 27 (permalink) Old 04-22-2004, 05:43 PM Thread Starter
Hi guys,
I need to tighten my trem claw screws to lower the bridge, but they are tightened all the way. The trem angle is near where it should be, but it needs a turn or two at least.
how do i remedy this problem
davester1234 is offline
post #2 of 27 (permalink) Old 04-22-2004, 05:49 PM
What's different? Bigger gauge?
Rich is offline
post #3 of 27 (permalink) Old 04-22-2004, 06:02 PM Thread Starter
nothing...
but i'm putting in the backstop, and I'm required to tighten the screws...but they're all the way tight already.
post #4 of 27 (permalink) Old 04-22-2004, 06:03 PM
Th4en the backstop is diferent
Back off it's springs some
Rich is offline
post #5 of 27 (permalink) Old 04-22-2004, 06:05 PM Thread Starter
back off the tremsetters springs??
post #6 of 27 (permalink) Old 04-22-2004, 06:07 PM
No, the Backstop's springs
Rich is offline
post #7 of 27 (permalink) Old 04-22-2004, 06:07 PM Thread Starter
the backstop is not even touching the bridge yet...
i just have no more room to tighten the trem claw springs at all, and I'll need to...
even if i wasn't installing the backstop, i have no room to address bridge height, so I'd like to get the screws in the middle again.
post #8 of 27 (permalink) Old 04-22-2004, 06:09 PM
Then again, what's different?
Rich is offline
post #9 of 27 (permalink) Old 04-22-2004, 06:10 PM Thread Starter
nothing dude,
It came from being setup that way, haven't had to adjust trem angle at all in over 6 months, but there's just no room to adjust, and I will need to tighten them a few turns for the counter pressure when the backstop is setup.
post #10 of 27 (permalink) Old 04-22-2004, 06:14 PM
10's on it? Is this an old guitar?
Rich is offline
post #11 of 27 (permalink) Old 04-22-2004, 06:16 PM Thread Starter
2003 jem 7vwh...
9's, no recent tuning changes.
haven't changed strings. Bridge isn't really out of position. But the bone heads just set it up so when the bridge is in the right position, you have NO more room to tighten the trem claw springs...zero. If you want to lower the bridge a HAIR, you can't.
post #12 of 27 (permalink) Old 04-22-2004, 06:19 PM
Either they changed your springs or your trem angle is no where near where it should be, at least not by how I figure it.
Rich is offline
post #13 of 27 (permalink) Old 04-22-2004, 06:20 PM Thread Starter
well, the setup was 6 months ago, the guitars been fine. No one has touched it. the bridge is right, man....give or take a mm or 2.
But i have no more room to adjust...what should I do?
post #14 of 27 (permalink) Old 04-22-2004, 06:23 PM
I'll explain why this makes no sense.
With the bridge at the correct angle in an 02' VWH you have around 1/4" of additional adjustment room.
In 03' they lengthened the trem rout to now there's near 1/2" of adjustment room when the bridge is at the correct angle.
Something isn't right.
Rich is offline
post #15 of 27 (permalink) Old 04-22-2004, 07:00 PM Thread Starter
I'll send you a pic in a little while okay..can't post it.
The trem angle is right man, by jemsite specs. its the same as the bridge in the pictures.
Unless they did something I don't know about.
claw screws , trem claw
Spring Claw screws bhuard75 Tech: Setup, Repairs and Mods 3 11-20-2011 03:41 PM
Edge Pro - problem with trem claw screws Shredie Tech: Setup, Repairs and Mods 9 09-29-2011 09:32 AM
Can't get arm to stay, tightened trem holder and everything... kalashnikov Tech: Setup, Repairs and Mods 5 10-09-2007 11:40 PM
Position of the Trem Spring Claw Screws on A JEM ? Metallion Ibanez JEM, UV, JS & Other Signature Models 13 09-17-2007 02:55 AM
WTB trem spring claw. nightfiend14 Classified Ads: Guitars and Gear 4 07-28-2006 01:56 AM
