TREM HELP!!!!!! - Jemsite
post #1 of 4 (permalink) Old 07-11-2011, 07:39 AM Thread Starter
Question TREM HELP!!!!!!
I've got an original Floyd Rose fitted to my pre 90's RG550. The Trem arm has the set up where the arm slides in and the outer collar screws down. If I want to play keeping the trem in posotion with my little finger whilst picking the required notes the trem has to be loose which means when you rattle the trem gently for the vibrato effect it's too loose in the bush it's inserted in and it rattle before making contact. If the collar is tightened the arm will not fall to the vertical position once released as the collar clamps the trem into place too harshly. I know the Ibanez Trems have the slot in arm with the two plastic bushes which is exactly the response i want, but as i'm permanently skint is there any slight mods you could make to the Floyd to try and get a little closer to that set up?
Cheers
RGgreen is offline
post #2 of 4 (permalink) Old 07-11-2011, 08:06 AM
Wink Re: TREM HELP!!!!!!
Since the Ibanez Edge is mainly THE floyd copy and many parts are interchangeable you could try to fit an Edge arm holder to it. It works the other way too(Schaller/Floyd Trem arm mod), and even if it doesn't fit, it is just a little loss. If that doesn't work, the only way to get that feel is to install an Edge/Lo Pro/Pro into your guitar. Hope that's helpful.
TheFreak777 is offline
post #3 of 4 (permalink) Old 07-11-2011, 09:12 AM
Re: TREM HELP!!!!!!
I have wondered this myself, and am pretty sure that putting some thin delrin/ptfe/uhmwPE washers under the screw clamp would allow for a better feel. I doubt if anything could be purchased stock that would work, though, so you'd need a lathe or a nicely gaged set of hole punches (or some other clever method for making thin, relatively high tolerance plastic parts)
andrewgosline is offline
post #4 of 4 (permalink) Old 07-11-2011, 12:21 PM Thread Starter
Talking Re: TREM HELP!!!!!!
Perfect, I didn't think about it that way (I was comparing it to the Ibanez trem arm by altering the bar and getting some of the C shape clips to slightly thicken the bar into the slot) hi strength thin plastic washers should allow the pin through the trem bar to 'dig' slightly into the washers allowing free movement e.g. washer to steel bush rather than the pin rubbing onto the bush which is very abrasive as well as noisy, as the pick ups sometimes pick up the grinding noise which is terrible at 50 watts!
Thanks very much for the help it's very much appreciated.
RGgreen is offline
floyd rose - edge
How to remove ZR trem, destroy it, then install Edge trem? bdk Tech: Setup, Repairs and Mods 16 07-25-2010 01:33 PM
Tut: Removing a Broken Trem Arm w/o Pulling the Trem (pics) SonataGuitarist Tech: Setup, Repairs and Mods 11 05-10-2007 02:57 AM
Ibanez AWD82Y with ACT trem. Info on the trem? The Euphor All Other Guitars (including Prestige) 0 01-13-2006 11:01 PM
Trem height and action problem. - Lowest possible trem heigh Theater of Dreams Tech: Setup, Repairs and Mods 2 04-29-2002 02:45 AM
Repairing trem knife edges - Trem on my JS1000 will not retu Jason Stone Archived Topics and Common Questions 2 01-01-2001 08:24 PM
