trem insert removal - Jemsite
post #1 of 8 (permalink) Old 12-15-2006, 05:59 PM Thread Starter
trem insert removal
Anyone have any ideas for removing the trem inserts from a guitar body without screwing up the finish? Is there a tool you can buy to do this? Any help would be greatly appreciated. Thanks.
lcsdds is offline
post #2 of 8 (permalink) Old 12-15-2006, 06:26 PM
Re: trem insert removal
Some people will tell you to use the stud and a claw hammer. That is not the way to do it if you want to avoid damage.
You need to pull it straight up. You need a long bolt or threaded rod that threads into the anchor, a nut that fits on that thread, and something like a wooden stick with a clearance hole for the bolt. Put the wooden stick down to span across the trem route with the hole above the anchor. Pad under the stick to protect the body finish. Put the nut on the bolt, insert it through the stick, and thread it into the anchor. Then turn the nut with a wrench, and it will pull the anchor up.
ryanb is offline
post #3 of 8 (permalink) Old 12-15-2006, 06:43 PM Thread Starter
I'll give this a try. Thanks!!!
lcsdds is offline
post #4 of 8 (permalink) Old 12-15-2006, 07:50 PM
You forgot to tell him he'll have to cut all the paint up to 1mm past the insert the entire perimeter or it'll all rip up.
There's nothing wrong with a claw hammer, or a cats paw [which I use], it's not rocket science to pull something straight up using either, but yes, you do want to pull them straight up.
Rich is offline
post #5 of 8 (permalink) Old 12-15-2006, 08:21 PM
Just use a bolt the same size as the posts, some oversized washers, that the insert will slip through, and a top washer, with a smaller hole, so the bolt has something to push against. I have this setup, use it all the time, and NEVER have any problems or dings.
Racerx2k is offline
post #6 of 8 (permalink) Old 12-16-2006, 01:58 AM Thread Starter
got them out without screwing up the finish. Thanks for the info guys, I appreciate it!!
lcsdds is offline
post #7 of 8 (permalink) Old 12-16-2006, 05:02 PM
You are right ... cutting the paint is important.
Yes, I agree it is possible to do it the "claw-hammer" method if you are careful, but many people aren't. If you just yank it out like a nail, you pull it sideways too and oval out the anchor hole. I don't like to recommend that method. But like anything else, there are lots of ways to do anything ... all of the mentioned methods work.
lcsdds -- glad you got them out OK.
ryanb is offline
post #8 of 8 (permalink) Old 12-16-2006, 05:19 PM Thread Starter
I'm glad I got them out without screwing up the finish too!! I just had these guitars finished by patrick and realized after putting them together that the edge inserts won't work with the ZR trem. They need to be the open base inserts to work. Thanks again guys for all your suggestions.
lcsdds is offline
guitar body
Replacement of your trem arm - "tutorial" with pictures Jammy Tech: Setup, Repairs and Mods 94 02-15-2012 04:40 AM
RG570, loose trem post stud insert leclaw All Other Guitars (including Prestige) 0 02-18-2006 10:46 PM
ZR Trem Removal BoSelectaMon Tech: Setup, Repairs and Mods 1 05-03-2005 09:05 PM
Trem angle wangbar Tech: Setup, Repairs and Mods 8 11-25-2003 06:37 PM
Repairing trem knife edges - Trem on my JS1000 will not retu Jason Stone Archived Topics and Common Questions 2 01-01-2001 09:24 PM
