trem setter installation - Jemsite
post #1 of 10 (permalink) Old 12-13-2005, 12:15 PM Thread Starter
Does anyone know where to get Trem Setters?
are they easy to install?
does it keep your guitar in tuner better?
eatsleepplayguitar is offline
post #2 of 10 (permalink) Old 12-13-2005, 12:27 PM
Re: trem setter installation
Which Trem Setter are you talking about?
buddroyce is offline
post #3 of 10 (permalink) Old 12-13-2005, 04:25 PM Thread Starter
http://www.hipshotproducts.com/tremsetter.htm
Heres the only one i can find
post #4 of 10 (permalink) Old 12-13-2005, 09:18 PM
mi2tom's Avatar
try the esp arming adjuster or the rockringer version.... if you want to get the esp arming adjuster .... buddroyce is experince in setting them up
mi2tom is offline
post #5 of 10 (permalink) Old 12-13-2005, 09:58 PM
Allparts sell them. That's where I bought mine.
They're fairly easy to install. Here's the instructions that come with it:
http://www.hipshotproducts.com/downl...structions.pdf
In section 3 it tells you how to drill the clearance hole for the shaft, but I REALLY recommend you use a longer drill-bit than stated. I've seen 14" long drill-bits that would be perfect.
This unit can dramatically improve tuning stability. You can adjust the tension on the unit as much as you like. Mine is set to a fairly high tension so that the trem is quite stiff, but the trade-off is that if I bend any string 2-5 half-steps all the other strings stay in tune while bending.
All in all it's a great unit but I'm about to remove mine and install a Tremol-No when they get released. It seems you can't have the 2 units installed at the same time. I've looked into it and the only units I've found that can be simultaneously installed with the Tremol-No are the ESP Arming Adjuster and the Rockinger Black Box mi2tom mentioned above.
Anyway, I hope this helps!
Awakened Sleeper is offline
post #6 of 10 (permalink) Old 12-14-2005, 01:24 AM
The hipshot tremsetter isn't bad, but I find it to be a bit of a pain to setup. I still swear by the ESP Arming Adjusters in my guitars.
(if you're interested in the Arming Adjuster, let me know as I'm getting rid of some of mine to get some cash flow since I quit my job)
post #7 of 10 (permalink) Old 12-16-2005, 12:31 AM
www.stewartmacdonald.com too.
john1880 is offline
post #8 of 10 (permalink) Old 12-17-2005, 10:11 PM
On the ESP Arming Adjuster and the Ibanez Backstop can you still pull up on the tremolo or what?
KrazyKris24 is offline
post #9 of 10 (permalink) Old 12-18-2005, 01:06 AM
Yes you can, but you can set it up so it almost doesn't.
post #10 of 10 (permalink) Old 12-18-2005, 08:48 AM
If you want to disable your trem, block it, if you don't leave it; That's what I think, if it ain't broke dont fix it
Regards
Jonny
PacificaJonny is offline
esp arming adjuster , hipshot tremsetter , ibanez backstop , trem setter
Trem Setter? evolvedmb Tech: Setup, Repairs and Mods 18 06-29-2005 10:31 PM
Trem setter Kontalonis Ibanez JEM, UV, JS & Other Signature Models 1 05-27-2004 07:48 PM
Hipshot Trem-Setter Problem Longhair Tech: Setup, Repairs and Mods 64 02-22-2004 02:20 AM
Trem-setter on RG2820? Vaituoso777 Tech: Setup, Repairs and Mods 1 12-29-2003 03:23 AM
Trem setter sap Tech: Setup, Repairs and Mods 5 12-18-2002 12:46 PM
