Trem tool removal - Jemsite
post #1 of 16 (permalink) Old 07-13-2015, 08:35 PM Thread Starter
Trem tool removal
I've got a guitar that someone added a allen wrench tool to the back of the headstock. It's one of the adhesive ones, not the screw in type. The issue is that it's partially covering the serial number. It's stuck on there REALLY WELL and i'm afraid if i try to remove it i'm going to take the serial number off. I'm debating whether to just leave it or try to remove it.
Do you think i'll be able to get it off and preserve the SN? what would be the best way to remove this with minimal damage?
I don't have pictures of the guitar at the moment, but can take one if that would be helpful. the tool that's on there is exactly like this one...
pwsusi is offline
post #2 of 16 (permalink) Old 07-15-2015, 05:47 PM
Re: Trem tool removal
That sucks... What kind of adhesive is it? Like a glue or like a double-sided foam tape? Can you tell?
FireEagle is offline
post #3 of 16 (permalink) Old 07-15-2015, 05:56 PM Thread Starter
I can't really tell, but i suspect it's double sided tape of some sort. They make this stuff super adhesive...it seems to be stuck on there really well.
pwsusi is offline
post #4 of 16 (permalink) Old 07-15-2015, 08:07 PM
RGTFanatic's Avatar
What kind of guitar is it Paul?
Actually, the better question is: Is the serial on a sticker or is it a decal that has clearcoat over it?
Sticker type:
decal type:
RGTFanatic is offline
post #5 of 16 (permalink) Old 07-15-2015, 08:12 PM
If its the clear gooey stuff it would be hell to get off and may take finish or numbers with it. If its the thin foam type double sided adhesive, you can use a thin wire to cut down the middle of it. I've obviously never done this on a guitar, but to remove something stuck on a wall with the double sided foam... You can loop a thin wire (like a high E string) over the top and just pull down and it cuts right through the adhesive. Then to remove the layer thats left on, you might be able to use a mineral oil based adhesive remover like Whisk or some other colorless non-harsh stuff. Rubbing gently and letting it soak in, etc... the oil just gets under the adhesive and lets it come off. They even have a gentle adhesive remover for tape residue on the skin in medical applications:
http://www.metromedicalonline.com/04170a.html#reviews
I don't want to say that you SHOULD try any of this... Just throwing some gentle removal ideas out there in case it helps! I'd definitely stay away from the acetones and alcohols during the process. Might be worth experimenting with some methods on similarly finished wood.
Good luck man!
post #6 of 16 (permalink) Old 07-16-2015, 06:13 AM
Warm it up with a hair dryer see if that helps loosen it.
Takin' a Ride is offline
post #7 of 16 (permalink) Old 07-16-2015, 06:52 AM Thread Starter
It's the decal type. Actually i didn't look close enough and never noticed this type of SN may have clear coat over it. That may work to my advantage
Good luck man!
Thanks guys, this helps.
pwsusi is offline
post #8 of 16 (permalink) Old 07-16-2015, 07:05 AM
Man, have you considered the possibility that this little thing with all the alen wrenches in place might actually heal some sustain issues of your guitar? People pay good money to install fat fingers on their headstocks.
panix is offline
post #9 of 16 (permalink) Old 07-16-2015, 12:12 PM
Wow man, are you serious?
Rafafas is offline
post #10 of 16 (permalink) Old 07-16-2015, 05:51 PM
I've read about people adding mass to the headstock to increase sustain, etc... Not sure if there is any truth to it or not.
Looking at the bright side though... at least you can tell the guitar was MIJ and what year without doing anything at all. Would be worse if the first part of the sn# was the part covered up...
post #11 of 16 (permalink) Old 07-16-2015, 06:32 PM Thread Starter
Well, this turned out to be simple. I wasn't aware there was clear coat over the SN. That plus a little heat and it's off and no damage to the SN
pwsusi is offline
post #12 of 16 (permalink) Old 07-16-2015, 07:13 PM
RGTFanatic's Avatar
Nice man..... I figured you wouldn't have any problem once I saw what kind of serial you have.
I'm diggin the rev head too. What's it attached to?
post #13 of 16 (permalink) Old 07-16-2015, 07:52 PM Thread Starter
Thanks man...and thanks for your help. it's attached to one of my 540p's
pwsusi is offline
post #14 of 16 (permalink) Old 07-16-2015, 09:51 PM
Certainly not one I sold you. I'd never do such a thing!
post #15 of 16 (permalink) Old 07-17-2015, 10:50 AM
Yeah but a couple of allen keys glued to headstock? i mean c'mon man.
Rafafas is offline
Edge Trem and Intonation Tool Inzane Tech: Setup, Repairs and Mods 5 02-17-2010 07:25 PM
Intonation tool for Edge trem. jazzedout Ibanez JEM, UV, JS & Other Signature Models 6 12-06-2007 06:10 PM
trem insert removal lcsdds Tech: Setup, Repairs and Mods 7 12-16-2006 04:19 PM
ZR Trem Removal BoSelectaMon Tech: Setup, Repairs and Mods 1 05-03-2005 08:05 PM
tool to remove the trem post set screws schmintan Tech: Setup, Repairs and Mods 2 02-05-2003 01:09 PM
