Tremolo high adjustment screw not working correctly. - Jemsite
 1Likes
  • 1 Post By TJ777
post #1 of 6 (permalink) Old 03-06-2019, 03:32 PM Thread Starter
Hey guys,
My english isnt super well, hope you guys understand what my problem is.
So I have a used JEM here from 2000 or something. I wanted to setup it however I cant get the action as low as I want it to be, and thats mainly cause of the reason that I cant go lower with the edge since the screw will stop here. The strange part is that the screw on the site of the high e-string can go lower than the one on the low e-string - is that normal? If so - why? If its not normal: did the base gets losend alittle or what happend, any idear?
The setting isnt bad overall, but if I woud be able to set the trem slightly lower (not much) it woud be perfect.
Greetings
GuitKaz is offline
post #2 of 6 (permalink) Old 03-06-2019, 04:26 PM
Re: Tremolo high adjustment screw not working correctly.
There should be a tiny locking screw inside the post screw. You have to unscrew that first by a couple of turns.
After adjusting the height lock the trem again.
TJ777 is offline
post #3 of 6 (permalink) Old 03-06-2019, 05:24 PM Thread Starter
That explains alot, I guess that was my problem then. Man holy I have like 10 Ibanez guitars and never needed to setup one of these.
GuitKaz is offline
post #4 of 6 (permalink) Old 03-06-2019, 05:37 PM
There is a good picture here: ??????? The Guitar Otaku: Ibanez and Gotoh Locking Studs
FireEagle is offline
post #5 of 6 (permalink) Old 03-06-2019, 08:08 PM Thread Starter
Ah See I didnt know that.
Well if I'm going to adjust that - anything to take special care about? Can I do something rly bad or something?
ty
GuitKaz is offline
post #6 of 6 (permalink) Old 03-07-2019, 02:44 PM
Look here. Best tech guide ever!
IBANEZ RULES!! tech - setup
FireEagle likes this.
TJ777 is offline
Edge Zero II screw not working Synpred Tech: Setup, Repairs and Mods 2 02-19-2018 06:11 AM
Edge tremolo spring adjustment screw size? o731 Tech: Setup, Repairs and Mods 0 01-28-2018 01:53 PM
How to check if new pickups are working correctly? Blenderernz Pickups & wiring 3 09-21-2010 03:16 AM
Removing tremolo anchors correctly? jemuniverse777 Tech: Setup, Repairs and Mods 1 05-30-2010 11:09 AM
circle of fifths + scales: not sure I get it correctly... choubix Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 8 07-10-2007 09:22 AM
