Tremolo issue - Jemsite
post #1 of 13 (permalink) Old 07-23-2015, 07:07 PM Thread Starter
FL6
Tremolo issue
Have you guys seen this before? I have a 350DXL. I had my neck off to do a fret dress and put it back on and the 4th and 5th strings are noticeably lower than all the others. It's not the neck because the difference in height happens right at the bridge. The action at the nut is perfect. All the strings' action are correct till after the 12th fret then it starts to drift. What ends up happening is when all the strings are at the correct action height the 4th and 5th strings are resting on the last fret but then drift up afterwards but again the height differential happens right out of the gate at the bridge.
I inspected the bridge closely but can't see anything abnormal. Short of taking it apart and reassembling it I'm not sure what else to do.
These pics aren't the greatest and doesn't quite capture what I'm seeing but it's quite dramatic and I hope it helps.
http://i.imgur.com/ShSxWzV.jpg
http://i.imgur.com/Q2ld9mU.jpg
FL6 is offline
post #2 of 13 (permalink) Old 07-24-2015, 03:36 AM
Re: Tremolo issue
Can't tell much from the pics, other than you are left handed. If bridge was disassembled, make sure saddles are in correct position. Some Floyd Rose type bridges have 3 different saddle heights, which creates the radius. Sometimes people shim the saddles to change radius to match neck .(shims fell out?) A kinked string could also be the cause of this. Hope this helps. If you post more pics, I will take a look.
Naked Ape is offline
post #3 of 13 (permalink) Old 07-24-2015, 07:57 AM Thread Starter
FL6
Re: Tremolo issue
I'm thinking it's a shim too. If it fell out I wasn't aware it was even there. What angle of pics would you like to see?
FL6 is offline
post #4 of 13 (permalink) Old 07-24-2015, 09:07 AM
Re: Tremolo issue
parallel to the strings.
panix is offline
post #5 of 13 (permalink) Old 07-24-2015, 09:37 AM
RGTFanatic's Avatar
Re: Tremolo issue
What year is the guitar? RG350's have come with 5 different bridge/trem units over the years. Each of the bridges are different in build and quality.
RGTFanatic is offline
post #6 of 13 (permalink) Old 07-24-2015, 09:40 AM
RGTFanatic's Avatar
Re: Tremolo issue
You can see in the first pic that the baseplate is stepped. This means that each saddle should be the same height.
After a better look, I'm thinking this is an EZII bridge, no?
post #7 of 13 (permalink) Old 07-24-2015, 10:19 AM
Re: Tremolo issue
Hey, which points to the "washer slipped under the saddle" theory
panix is offline
post #8 of 13 (permalink) Old 07-24-2015, 11:25 AM Thread Starter
FL6
Re: Tremolo issue
What washer?
FL6 is offline
post #9 of 13 (permalink) Old 07-24-2015, 11:26 AM Thread Starter
FL6
Re: Tremolo issue
Yes, EZII
FL6 is offline
post #10 of 13 (permalink) Old 07-24-2015, 11:36 AM Thread Starter
FL6
Re: Tremolo issue
Here's 3 more.
http://i.imgur.com/NCbghVo.jpg?1
http://i.imgur.com/YbWvozU.jpg?1
http://i.imgur.com/7tYe6vE.jpg
FL6 is offline
post #11 of 13 (permalink) Old 07-24-2015, 02:48 PM Thread Starter
FL6
Re: Tremolo issue
I figured it out, sorta. The base plate that the saddles sit on has 3 height settings, roughly 4mm-E, 4.3mm-A, 4.6mm-D, 4.6mm-G, 4.3mm-B, 4mm-e. The saddles come in 2 heights, 11mm and 11.3mm.
Mine were all mixed up so I think I got the saddles mixed up years ago when I was cleaning it.
I put it back together using the taller saddles for the E, A, D strings, and the shorter saddles for the high strings. Not sure if that's exactly how it should go but it made sense to me.
Plays great now.
FL6 is offline
post #12 of 13 (permalink) Old 07-24-2015, 03:50 PM
Re: Tremolo issue
You actually want the taller saddles for the middle strings, to try to match the radius of the board (though on a six string I'd expect an even number, either 2 or 4). But, as long as it's working. :yesway:
Drew is offline
post #13 of 13 (permalink) Old 07-24-2015, 04:51 PM Thread Starter
FL6
Re: Tremolo issue
I wondered about that but the plate under the saddles is already raised for the middle strings. I might try it that way anyway.
Here's a pic.
http://i.imgur.com/H0MpRjd.jpg
FL6 is offline
350dxl
Edge Zero tremolo arm issue satchtabber Tech: Setup, Repairs and Mods 18 07-08-2015 08:05 AM
LNG 777 tremolo issue sonny13 Ibanez JEM, UV, JS & Other Signature Models 7 02-25-2014 11:54 PM
Zr tremolo arm issue Ek87 Tech: Setup, Repairs and Mods 1 10-06-2010 01:10 PM
Double Edge Tremolo Issue RG1820X Pickups & wiring 0 11-30-2008 05:37 PM
ZR Tremolo issue Clydefrog All Other Guitars (including Prestige) 1 07-12-2007 12:48 AM
