Tremolos that fit Jem Jr? - Jemsite
post #1 of 16 (permalink) Old 03-04-2017, 05:59 AM Thread Starter
Does anyone know what Tremolos fit into the routing of a Jem Jr?
Was gonna order a Gotoh FR or a Floyd Rose Special because the ibanez' terms are very expensive.
Is the Floyd Rose Special good enough or will it be worth it to get the more expensive Gotoh or Schaller Floyd Rose?
linus is offline
post #2 of 16 (permalink) Old 03-06-2017, 08:35 PM
Re: Tremolos that fit Jem Jr?
I don't know if the Floyd Special fits but I would avoid it, it's probably not much better than what is on your Jr at the moment. I have a cheap LTD guitar with one and I'm having tuning issues with it.
Have you look at these:
http://www.stewmac.com/Hardware_and_...lo_System.html
The base plate looks very similar as the one on the Jr. Check the specs and measure the one on your Jr.
BenoA is offline
post #3 of 16 (permalink) Old 03-19-2017, 12:13 AM
Id say its worth it to get the Gotoh 1996t, I recently did a full upgrade on my Jr with the 1996t and its great and has great stability, just dropped right in (except for the studs but I just used the factory studs for now)
Opendome is offline
post #4 of 16 (permalink) Old 07-02-2017, 01:59 PM Thread Starter
OK, 1996 then. A guy on YT used the FR Special but had to take it to a luthier because the base plate scratched the corners of the cavity when the trem was used & the but didn't fit at all.
Does the Gotoh 1996 nut fit directly onto the Jem Jr as well?
I'm not a heavy tremolo user & think the Ibanez DL works pretty great for me but the sustain sucks. It's definitely better than what was on my previous budget Ibanez rg270.
Does anyone know what kind of brass block would fit an Ibanez DL, if the screw holes for those intended for FR, Gotoh or Edge?
linus is offline
post #5 of 16 (permalink) Old 09-29-2017, 11:19 AM
Rather than start a new thread, I am piggy backing here... Linus I hope you don't mind.
I also have a Jem Jr that I just purchased and am looking to replace the Standard DL tremolo. Based on the research I have done, the best options for replacements are the Gotoh 1996t (about $95-$110) or an Original Floyd Rose ($200-$230). My understanding is that both are drop in replacements. With the OFR, I can utilize the new studs without any body modifications. The Gotoh would require me to use the original studs or modify the body if I want to use the supplied studs.
I've never owned a guitar with an actual OFR nor the Gotoh. I'm wondering if it is worth spending the extra money on the OFR. I've seen people post that the Gotoh is just as good but then again, if I am not replacing the studs on the Gotoh, does it make better sense to go with the OFR? Anyone want to offer their opinion or Knowledge?
Sportrider24 is offline
post #6 of 16 (permalink) Old 09-29-2017, 08:42 PM
For those who are interested I just purchased an Original Floyd Rose in black nickel tonight. I chose an R3 nut and feel that the provided 38MM trem block will fit based on measurements I took from the original DL trem and space in the cavity. I will report back in a few days after I receive it and have had time to install it to confirm fit.
post #7 of 16 (permalink) Old 10-09-2017, 08:40 AM
Update: The tremolo swap went seamlessly. The OFR was a direct drop in replacement. The only parts from the OFR that I didn't use was the wood ferrules or the string tree. Both would have fit but I saw no point in changing them. The OFR studs screwed into the original ferrules just fine.
post #8 of 16 (permalink) Old 10-09-2017, 08:54 AM
Is there difference in sound and sustain?
peromucho7 is offline
post #9 of 16 (permalink) Old 10-09-2017, 10:09 AM
I can't say that it sounds any different but then again, I'd only had the guitar for a week before I made the change. I can say that it sustains better but I also adjusted the setup while changing the tremolo. The biggest difference I noticed (beyond the obvious quality improvement) was the ease of use. The OFR just floats much better. The Standard DL seemed much more stiff and I also had to give it an extra pull back sometimes to bring it back to level.
post #10 of 16 (permalink) Old 10-11-2017, 09:07 AM Thread Starter
Someone on YouTube said he did the switch but that the baseplate on the OFR was touching the edge of the routed cavity when bending the bar toward the body / divebombing. That "hook" part of the baseplate that surrounds the stud is different on the OFR compared to the Ibanez DL, Edge & Gotoh's
You didnt have this problem?
If so, I think I'll buy the FR Special
linus is offline
post #11 of 16 (permalink) Old 10-11-2017, 10:36 AM
Nope. I'm not having that problem at all. I wonder if they used the studs supplied by Floyd Rose or the Ibanez studs?
post #12 of 16 (permalink) Old 01-19-2018, 04:28 PM
I can confirm that an OFR fits JEM JR. Even the existing posts worked. I had an original Made in Germany 1985 OFR lying around cuz I removed it from my 1985 Gibson to change color and install the Ghost system. Only difference was the block on my OFR is longer. Appeared that I could have swapped with the shorter Ibanez but I decided to keep it and just not use the back cover instead as the Floyd block is so beefy and high quality. Guitar gained some sustain as a result and is a bit smoother action when using the tremolo.
avalon173 is offline
post #13 of 16 (permalink) Old 01-20-2018, 10:17 PM Thread Starter
OFR costs 250 in Europe (1/2 a Jem Jr) & a Gotoh costs 140 - Is there a downside to using the Jem Jr studs instead of the Gotoh studs that won't fit?
FR Special is 100 & is a direct replacement, made in Korea copy with the same specs as the OFR with the only difference that its tone-block & saddles are made out of zinc alloy instead of brass & steel. I have an L shaped 32mm brass block that fits an FR trem but zinc saddles - is it a big deal?
linus is offline
post #14 of 16 (permalink) Old 01-21-2018, 04:00 AM
Instead of OFR buy Schaller Lockmeister,
I put one in yesterday, and it is more then great.
So far only problem is that thing flutter for 4 seconds or more if I dont stop it, hahaha.
You should buy one with 37mm block and R3 nut,
(but I Bought gold with 42mm block, and R2 nut, wanted heavy block and slightly narrower locking nut then previous.)
post #15 of 16 (permalink) Old 01-21-2018, 04:02 AM
And Schaller studs are matching previous wood inserts, so I left those wood inserts and just screw new Schuller studs in.
What tremolos fit? Audacity All Other Guitars (including Prestige) 2 10-15-2011 01:52 PM
Will this fit my Jem 7V Thendrall Off-topic / Miscellaneous 0 02-05-2011 02:46 AM
Kahler Tremolos vs. Floyd Rose/Floating Tremolos Part A FarBeyond Gear, Equipment, Recording & Off Topic 87 11-24-2009 03:21 PM
Will Jem 7V neck fit Jem 555 body? indeedido Ibanez JEM, UV, JS & Other Signature Models 32 08-25-2008 06:39 PM
Swapping necks, will a Jem neck fit an RG? - Can I put a Jem djrjems Tech: Setup, Repairs and Mods 5 09-29-2001 01:14 AM
