Trouble with flutter on Universe - Jemsite
post #1 of 7 (permalink) Old 11-07-2004, 10:06 AM Thread Starter
Hey folks, I am curious. How does Steve pull off the awesome flutter on the Passion and Warfare album while no matter how I do it on my Universe it sounds like a fart?
Is it all in the springs for the tremelo? Or is it with how much you break in the springs for the tremelo?
This has always bothered me, because when I pick up a six string guitar I can flutter the bar no problem. But when I pick up a 7 string, the bridge snaps back making a very bad sound to where the flutter is barely audible over the sound of the bridge and strings (no matter how much muting I do).
Any Advice? Or is it a 7 string thing?
linthat22 is offline
post #2 of 7 (permalink) Old 11-08-2004, 02:35 AM
maybe because he stuffed the springs cavity with tissue paper?
napee is offline
post #3 of 7 (permalink) Old 11-08-2004, 09:47 PM
It's all of those things, plus it's got to do with where the saddles are on the bridge when it's properly intonated (further back lends itself to more flutter, but more height variance when using the trem)... and you'll get more/better flutter if your bar is tight such that it holds its position when you let it go (this is how I insist my bars stay; right where I put them).
There's a lot more poundage of tension pulling on a 7-string bridge with that extra string, and that stiffens things up quite a bit.
The condition of your trem posts and knife edges also affects this; the better the condition, the more flutter you'll get.
Many factors...
steve is offline
post #4 of 7 (permalink) Old 11-11-2004, 01:37 AM
steve is right. it involves many factors. another thing would be if the trem posts are not level with each other, you'll get less flutter. even the position of the tremolo. if it's leaning back too far, you may get less flutter.
even if the tremolo arm bushing is loose, it could affect the amount of flutter. check everything, especially the posts and knife edges. make sure nothing is rubbing anywhere.
i've seen this a few times. one of the saddle screws is sticking out too far and touching the wood underneath. "many factors" to quote steve again.
and you'll need to check all of them. :-)
john
john1880 is offline
post #5 of 7 (permalink) Old 11-27-2004, 02:01 PM Thread Starter
Thank you everyone. And here I was thinking it was going to be an easy answer
post #6 of 7 (permalink) Old 11-27-2004, 08:33 PM
Check to see if the edges of your trem are hitting the pickguard. If so, check the tech pages at www.ibanezrules.com for a quick and well done fix.
Kontalonis is offline
post #7 of 7 (permalink) Old 11-28-2004, 03:17 AM
Make sure the arm socket is nice and tight in the base also. If it's a bit loose it can counter-act the flutter and make a ton of noise in the process.
pinto79 is offline
string bridge , tremolo arm
Does your Universe flutter? Chompers777 Ibanez JEM, UV, JS & Other Signature Models 9 09-10-2011 10:19 PM
what is flutter? scotte_za Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 11 12-23-2007 10:28 AM
Which Edge has the best flutter? Devon8822 Ibanez JEM, UV, JS & Other Signature Models 22 09-20-2007 02:34 PM
Improving flutter? GuyAlexander Tech: Setup, Repairs and Mods 38 04-07-2007 08:56 PM
Whammy Flutter moby All Other Guitars (including Prestige) 1 12-08-2004 02:04 PM
