Truss Rod Routing Depth?? How Deep is too Deep? - Jemsite
post #1 of 4 (permalink) Old 12-28-2003, 02:29 PM Thread Starter
On the StewMac website, they list the routing depth for their "Hot Rod" truss rods as 7/16", measured from the bottom of the fingerboard. Now maybe it's just me, but that doesn't leave a whole lot of wood between the bottom of the routed channel and the back of the neck. Does that seem a little deep?
Anybody got a better recommendation for truss rods for Ibanez or other thin necks?
TAorama is offline
post #2 of 4 (permalink) Old 12-28-2003, 02:45 PM
think you'll need a single rod truss rod,isn't the one your talking about have 1 rod over the top of another?
Rob
Jem7RB MK is offline
post #3 of 4 (permalink) Old 12-28-2003, 04:42 PM Thread Starter
Yes, the "Hot Rod" is a 2-rod setup. Is there an advantage to that over the stock single threaded rod with a flat bar attatched to it (other than clearance)? Which of the other rods would you recommend? Also, do the truss rod kits normally come with the flat bar and the barrels to go over the truss rod? I didn't see that mentioned on the StewMac web site.
TAorama is offline
post #4 of 4 (permalink) Old 12-28-2003, 05:01 PM
The hot rod can counteract a backbow. That's why they are made of two threaded rods, because there is mid-point where there is no tension, but it will bow in either direction. The flat top dual rods just correct a forward bow, and the nut will go loose when there's no more tension. The hot rod is a good rod, and I used it for one wizard style neck, but I took about 1/32nd off the fretboard thickness to put the rod more in the center of the neck. The thickness at the bottom of the channel is of little consequence since the rod will not be pushing against that part of the neck. It will be pushing up on the fretboard and back on the heel and headstock area. With any non-traditional dual rod, I recommend having a volute. There is no reason not to. You need extra meat there, but not necessarily under the rod along the back of the neck.
frankfalbo is offline
truss rod , truss rods
NGD RG3120 Deep Red Grimlord All Other Guitars (including Prestige) 15 03-28-2012 06:40 PM
Deep 6 Guitars Kelly Briggs All Other Guitars (including Prestige) 7 08-01-2010 01:40 PM
Another new toy for me.. Im going into the deep end here ibanezcollector Gear, Equipment, Recording & Off Topic 3 02-05-2007 08:29 AM
am i going to deep? Dragon Slayer J Tech: Setup, Repairs and Mods 6 01-09-2007 07:00 PM
Deep down into the pain solo. - Need help. firegarden Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 0 01-11-2002 10:58 PM
