Tune Stability Problems - Jemsite
post #1 of 9 (permalink) Old 01-05-2006, 06:09 AM Thread Starter
Ok i got to admit, iam not really good with the technical parts of the guitar, all i can do is play it, and play it good.
Recently I have switched to trem guitars and not know anything i stupidly restrung all the strings at once for 3, 4 times. And about 3 weeks after my last string change the pitch changes dramitcally all of the sudden. I dont think its the weather although it got very very very humid. sigh. Hong Kong. Anyways whats the problem. Nuts are tight. The screw that holds the string on the trem is tight. The allen bolts at the back of the neck are tight too.
Whats wrong?
klp2332 is offline
post #2 of 9 (permalink) Old 01-05-2006, 06:42 AM
Davey's Avatar
Re: Tune Stability Problems
Originally Posted by klp2332
Nuts are tight.
That's a little too much information, are you nervous?
Only joking mate, it could be to do with the neck bow from the sounds of things (what with the humidity.) Just take it to a tech for a setup, unless the guitar is crap and you fancy experimenting, but the truss rod is something you need to do in really small stages, otherwise you can damage your guitar permanently.
Hope that helps!
Davey is offline
post #3 of 9 (permalink) Old 01-05-2006, 06:44 AM
Davey's Avatar
Oh wait, is the bridge level? check out the tech section, it's a wealth of information
Davey is offline
post #4 of 9 (permalink) Old 01-05-2006, 06:46 AM Thread Starter
bridge level is now even. Its a jem which i bought only 6 months ago. Do i really need a tech only after 6 months. How much does a full resetup cost anyways.
klp2332 is offline
post #5 of 9 (permalink) Old 01-05-2006, 06:57 AM
check to make sure the locking nut hold downs are seated properly.....and double check to make sure the locking nut screws on back of neck are tight.but not to tight are you will crack the neck.....
honky_tonk is offline
post #6 of 9 (permalink) Old 01-05-2006, 07:17 AM
Davey's Avatar
Full setup in the UK can run 25-40 plus strings depending on who does it, not sure where you are from though mate.
Davey is offline
post #7 of 9 (permalink) Old 01-05-2006, 10:06 AM Thread Starter
I checked the intonation and its a bit off. 12fret e string is higher then open e string. i only tried this on 1 tuner but it sure its pretty accurrate.
And there are some fret buzz on the 4th 5th and 6th string near the 24th fret.
klp2332 is offline
post #8 of 9 (permalink) Old 01-05-2006, 11:34 AM
Davey's Avatar
Take the plunge, a pro setup is the way to go and just be careful when changing strings in the future.
And don't talk to strangers.
Davey is offline
post #9 of 9 (permalink) Old 01-05-2006, 11:35 AM
Davey's Avatar
Davey is offline
fret buzz , locking nut , neck bow , trem guitar , truss rod
Need help: problems with tuning stability (zr trem) suds16234 Tech: Setup, Repairs and Mods 12 02-04-2011 05:18 PM
Tuning stability problems maliciousteve Tech: Setup, Repairs and Mods 5 10-13-2007 12:44 PM
Unusual String Breakage and Tuning stability problems junebughunter Ibanez JEM, UV, JS & Other Signature Models 9 11-08-2005 12:50 PM
Tuning stability problems..... Lifeson22 Tech: Setup, Repairs and Mods 7 08-27-2005 12:47 PM
Tuning stability problems KevJEM7D Tech: Setup, Repairs and Mods 8 07-08-2005 12:30 PM
