Tuning to.... - Jemsite
post #1 of 9 (permalink) Old 12-18-2005, 07:46 PM Thread Starter
Reviews: 5
Tuning to....
whole step down on my ibanez RG
what is the best string gauge to use that wont screw my tremolo??
wildchild247 is offline
post #2 of 9 (permalink) Old 12-18-2005, 07:59 PM
Re: Tuning to....
Whole step down is nothing major, .10 should be perfect. .9 or .11 would work fine, your pick really.
pawel is offline
post #3 of 9 (permalink) Old 12-18-2005, 09:02 PM
Re: Tuning to....
A set of 11's tuned down a whole step would require minimal spring tension adjustment, but a set of 10's would work as well.
buddroyce is offline
post #4 of 9 (permalink) Old 12-19-2005, 03:40 AM Thread Starter
Reviews: 5
Re: Tuning to....
cheers thanks
post #5 of 9 (permalink) Old 12-19-2005, 05:30 PM
Lightbulb Re: Tuning to....
I'd try 10's or 11s, 9's will buzz quite a bit...
Regards
Jonny
PacificaJonny is offline
post #6 of 9 (permalink) Old 12-19-2005, 06:08 PM
Re: Tuning to....
I use normaly 10's and with drop tunigs 11's. Eb tuning on my scalloped strat I use 11's because I get much better grip then. 9's are always too light for me, I guess I have pretty agressive attack.
shredfreak is offline
post #7 of 9 (permalink) Old 12-19-2005, 06:25 PM
Re: Tuning to....
just a matter of spring fiddling really - have a look at some of Rich's setup tips on Ibanezrules if you want to know more
David McCarroll is offline
post #8 of 9 (permalink) Old 12-22-2005, 11:14 AM Thread Starter
Reviews: 5
Re: Tuning to....
So what exactly should I use on my ibanez note that I have a tremolo so it is harder to use real beefy strings
could you give the optimal gauges for whole step down drop C, step and half down, drop b
also I was going to drop c on my ibanez and I used 10 - 52 (bad idea)
It rasied the tremolo way too high (even with tension at max with four springs so I tuned to drop b to see what it sounds like and its real heavy)
thanks
wilchild
post #9 of 9 (permalink) Old 12-23-2005, 01:42 AM
Re: Tuning to....
I normally play with 10s on all of my guitars in standard tuning, although I've found that 10s a half step down feels even more comfortable. My main guitar (a custom RG370DX) is in Drop C tuning (C G C F A D) and I have found that the perfect string gauge for the job are a set of Ernie Ball Power Slinky's to which I have swapped the .048 string with a .052 string so that all the strings have about the same amount of tension on them. The guitar plays and sounds awesome with this setup and it didn't require a whole lot of trem adjustment. I did, however, have to get the intonation re-adjusted but you have to do that whenever you change your tuning.
lyconxero is offline
ernie ball
Different tuning?? callen3615 Polls 36 05-02-2010 10:17 PM
Tuning to 463 Hz?? kirk Tech: Setup, Repairs and Mods 8 10-23-2006 01:15 PM
korean locking nuts - loosin tuning does the hardware finish matters on tuning?? jlander Tech: Setup, Repairs and Mods 4 08-01-2006 08:43 PM
De-Tuning a JEM? Spinstorm Ibanez JEM, UV, JS & Other Signature Models 6 06-09-2004 11:10 AM
Tuning to E - Can't get back to E tuning with my UV777 Zmuzic Ibanez JEM, UV, JS & Other Signature Models 6 07-25-2001 12:12 AM
