Tuning makes bridge lift way up? - Jemsite
post #1 of 5 (permalink) Old 07-01-2011, 12:53 PM Thread Starter
I have two RG guitars. Both used pawn scores.
One is missing the locking nuts and that one when tuned lifts the darn bridge stupid high! What am I doing wrong?
Jay21 is offline
post #2 of 5 (permalink) Old 07-01-2011, 01:02 PM
Re: Tuning makes bridge lift way up?
Not setting the guitar up properly.
musikron is offline
post #3 of 5 (permalink) Old 07-01-2011, 01:02 PM
Reviews: 98
It's not set up properly. How may trem springs are installed? Make sure to screw in the trem claw screws a turn or two at a time, retune, and see if the baseplate id parallel to the body. Go here for reference:
http://www.ibanezrules.com/tech/setup/angle.htm
AlaskaBat is offline
post #4 of 5 (permalink) Old 07-03-2011, 06:20 PM
Reviews: 11
Used to have the same prob long ago before i learned. When you tune higher, you make the strings tighter, which in turn pulls on the tremolo, which you must adjust in conjunction to fix the height anD action.
Bryancap77 is offline
post #5 of 5 (permalink) Old 07-03-2011, 11:52 PM
Reviews: 21
Relax the tuning on the strings until the bridge goes back to being just below level.
Open up the back of your guitar by removing the plate (if you need to, some you can access the trem springs through gaps in the plate) and tighten the screws that attaches the trem claw to the body.
Retune the guitar and see where the bridge sits.
How much to tighten them is really trial and error, if you find you tighten the screws up until you don't have any more room for movement you might have to do what AlaskaBat mentioned and add a trem spring or 2 to the block.
Another quick thing, if you find you have 3 springs on the block attached to the claw and they are straight, you can get a bit more tension by placing the outer two diagonally to the claw, so the end poles on the block attach to positions 2 and 4 of the claw. (1 and 5 being the outer fingers of the claw 3 being the middle).
Hope this helps.
D1m3b4g2 is offline
Help with Ibanez ZR2 bridge tuning problem Arycama All Other Guitars (including Prestige) 4 09-16-2010 04:39 AM
Changing string/tuning with Edge Pro bridge 70Seven Tech: Setup, Repairs and Mods 4 04-26-2008 01:40 AM
Tuning a floating bridge werx Ibanez JEM, UV, JS & Other Signature Models 8 04-10-2007 10:22 AM
Tuning a floyd rose bridge... guitar_legend Tech: Setup, Repairs and Mods 4 02-07-2007 08:08 PM
Ground Lift kirk Gear, Equipment, Recording & Off Topic 9 10-25-2002 10:32 AM
