TZ-30 tremolo block replacement options - Jemsite
 1Likes
  • 1 Post By LonePhantom
post #1 of 10 (permalink) Old 08-02-2017, 02:42 AM Thread Starter
I have an Ibanez SCR220 which could use a new tremolo block for its TZ-30 bridge. Here is some information about the bridge: TZ-30 | Ibanez Wiki | FANDOM powered by Wikia
The TZ-30 was on other Ibanez models and has a heritage starting with the TZ-II/TZ-6 all the way up to the SynchroniZR bridge which I am not very familiar with. Additionally, taken directly from the link: "The TZ-30 employs a non-locking, double pivot design which is reminiscent of early Fender tremolos."
My gut tells me looking for the block off a TZ-30 is probably not going to yield much. Fender replacement parts seem to be readily available. If someone happens to have a TZ-30 lying around, I would be interested, but I feel I might have more luck with Fender or the multitude of generic Fender parts on the market. If anyone has any experience with anything remotely relating to this thread, please chime in. I understand it is hard to be interested in a guitar most people have never heard of, much less the tremolo block for the bridge on that particular guitar, but if you have a solution, please share! If you were in my situation, what would you do? You never know what other people know until you ask or present a situation someone has already gone through. With that said, I do wish it was a less random problem on a more common guitar. Thank you for any help you can offer!
Formerly Given To Fly is offline
post #2 of 10 (permalink) Old 08-02-2017, 09:08 AM
site founder 0% owner
jemsite's Avatar
Re: TZ-30 tremolo block replacement options
What is wrong with the existing tremolo block?
jemsite is offline
post #3 of 10 (permalink) Old 08-02-2017, 05:13 PM Thread Starter
The section where the tremolo bar screws in broke apart. I think the tremolo bar would press against the side of the tremolo block every time I used it causing that section of the block to eventually break apart. The tremolo still works normally so it took me awhile to figure this out.
post #4 of 10 (permalink) Old 08-02-2017, 07:23 PM
Reviews: 120
can you get the post spacing for the bridge? There may very well be a viable option from Gotoh, Wilkinson, et al, that could be a drop-in replacement.
LonePhantom is offline
post #5 of 10 (permalink) Old 08-02-2017, 08:54 PM Thread Starter
Does 55mm sound like it makes sense? I measured from the center of each post.
post #6 of 10 (permalink) Old 08-02-2017, 09:43 PM
Reviews: 120
I'd probably just upgrade the whole unit then, based on those measurements/ I wonder if a gotoh unit with 56mm spacing, for example would work for you:
Tremolo 510 Series | Product Categories | G-GOTOH Ltd.
post #7 of 10 (permalink) Old 08-02-2017, 11:57 PM Thread Starter
I'm pretty sure one of these would be a direct replacement, more or less. Thank you for the link! I would rather not replace the whole bridge but now I know where to go if it comes to that.
Looking back, when I found the pieces of the tremolo block that had broken off, I thought they were made of plaster or concrete of some type because that is what the material looked and felt like. Knowing guitars are not made from either of these materials, plus the fact everything worked just as it had before I found the pieces, I decided to file it away in the "that's odd" folder of my memory. What exactly is the tremolo block made out of? Even without a picture, I imagine an educated guess would be an accurate guess.
post #8 of 10 (permalink) Old 08-03-2017, 12:49 AM
Reviews: 120
I'd say it would be similar to the Ibanez bridges, in that its some mystery, soft pot metal alloy. To just replace the block you're going to need to do a bunch of measurements and see if anything on the market matches the specs of your block. They may or may not be "standard size" as it were.
post #9 of 10 (permalink) Old 08-17-2017, 10:16 PM Thread Starter
I spoke with my guitar tech today. The situation does not seem favorable. Thank you for your help Lone Phantom! I never thought a block of metal would be quite so complex.
post #10 of 10 (permalink) Old 08-18-2017, 02:27 AM
Reviews: 120
No worries, just go for the bridge change. It'll likely be the simplest thing, and may even improve the tone
ibanez scr220
Trem replacement options 440sII Kaldorlon All Other Guitars (including Prestige) 6 03-23-2012 04:19 PM
Anyone installed a big block replacement for their Edge 3 tremolo?? modulo All Other Guitars (including Prestige) 6 11-02-2011 06:29 PM
Edge Zero replacement options. scotteggshell All Other Guitars (including Prestige) 8 02-25-2009 07:32 PM
Ibanez RG neck replacement options cosmitron Tech: Setup, Repairs and Mods 1 12-07-2007 10:36 AM
G-Major replacement options? JiMoSiTY Gear, Equipment, Recording & Off Topic 14 03-11-2004 07:33 PM
