unstable sounds from my new 7vsbl (2k3 edge pro) HELP ! - Jemsite
post #1 of 6 (permalink) Old 05-06-2004, 12:37 PM Thread Starter
i have been having a sound problem with my guitar the sustain is still pretty good but i am getting unclear note definition . when i sustain a note
on any string on the jem i get that warbly sound like when u hit the 12th fret on the high E (thin string) when the strings are dead and caked with crud. First i thought it was fret buzz so i had the neck straightend out and the action raised and the fret buzz has gone everywhere and it is still doing it. Then i thought mabee it was the pickup height/string pull so i have bottomed them out flush to the pickguard and it is still doing it. Now i think i have figured it out that there is something loose on the trem because when i stike a note any note, hit any open harmonic,open string and any string at the 24th fret , the sound still "warbles". It almost sounds like when u hit certian notes on the guitar and the springs resonate BUT IT IS NOT the springs ,the trem itself seems to be resonating. Also i would like to add that if i palm mute a note and let a note sustain it does not do this at all. i also have the springs tissue paperd so the springs do not resonate. does this sound like my problem or am i just crazy??? any input would be muchly appreciated.
Jagermeistro is offline
post #2 of 6 (permalink) Old 05-06-2004, 12:48 PM
Are u using straplocks? This happens to me all the time. They get loose and resonate.
Also where does the sound come from?.. the amp or only from guitar?
c0un7d0wn is offline
post #3 of 6 (permalink) Old 05-06-2004, 12:55 PM Thread Starter
the straplocks are tight and the you can hear the note and the "resonationg note" kinda fighting with eachother through the amp and by putting your ear to the wood of the guitar.
post #4 of 6 (permalink) Old 05-06-2004, 01:09 PM
If it was just one string doing it I'd say it's porbably sympathetic vibration of a loose saddle tail, but you say all strings do it. I would still take your fretting hand and palm mute the saddle tails alone just to rule it out though. Have you made sure the nut is snugged up? [not "tight", you don't want to crack the wood]
Rich is offline
post #5 of 6 (permalink) Old 05-07-2004, 01:31 PM Thread Starter
thankz guys for the feedback guys i tried tightening up the nut and mabee its the truss rod? i dont know what it is anymore i think i might just take it back and get a new one since im stil under warranty my $1800 guitar shouldnt be doing this.... thanks for all the help guys
post #6 of 6 (permalink) Old 05-07-2004, 02:03 PM
dex
Could be the trem arm holder - make sure everything there is tight.
Tighten up the metal plate that is holding the springs in the trem block and if that doesn't help try and put some tension on the trussrod.
If it's still doing it after that see if all the tining machines are tight in the headstock.
ilia
dex is offline
arm holder , fret buzz , palm mute , pickup height , trem arm , trem arm holder , trem block , truss rod
Unstable tuning MatiasTolkki Tech: Setup, Repairs and Mods 38 01-06-2015 12:59 PM
help with unstable edge tremelo Tahoebrian5 Tech: Setup, Repairs and Mods 1 12-26-2011 12:20 PM
Fp2 unstable tuning Johannnesss Ibanez JEM, UV, JS & Other Signature Models 6 04-19-2011 10:39 AM
Custom Knife Edge, Locking Nut, and Stud Bolts Hardening? (Sorry if it sounds crazy) theapprentice Tech: Setup, Repairs and Mods 10 05-07-2008 10:51 AM
A possible fix for that unstable neck. mlr_pa Tech: Setup, Repairs and Mods 0 11-02-2005 01:27 PM
