Unstopable fret buzz - Jemsite
post #1 of 12 (permalink) Old 09-17-2011, 02:48 AM Thread Starter
Im going insane. I have an RG321MH and I cant get rid of this buzz. Its going on all through the bottom three strings mostly on the E and A it stops high up on the neck but its just a slight buzz but loud enough to hear through the amp. Ive dressed the frets and checked them time and time again, they are definetaly level. Ive tried everything, raised the action, shimmed the nut that I filed down, and given it tones of relief. cant figure it out. I was thinking it might be the slots on the nut since Im running 11-54's, I dont know any help would be appreciated.
JBOrocks is offline
post #2 of 12 (permalink) Old 09-19-2011, 01:59 PM
Re: Unstopable fret buzz
This is the problem with trying to handle tech work yourself. Replacing a pickup or switch, the novice can do, but fret and nut work? You guys crack me up trying that when you have no clue what it is you are doing. You have done more damage than good. Take it to a good luthier and pay him more to undo your mistakes than it would have cost to just have it fixed in the first place.
musikron is offline
post #3 of 12 (permalink) Old 09-19-2011, 07:36 PM
Way to slam the noobs......
If the buzz is even the fretwork is probably clean. Buzz has as much to do with you and the way it's setup as anything else. Ifr you pick too hard, or with poor technique, or too sloppy for the setup, you'll never get rid of the buzz, until you change you, or the setup. Strings also have alot to do with it, try a set of DR Tite Fits which buzz about 1/2 as much as a set of D'Addario's.
Or change the setup until it cleans up enough for you and get used to playing it that way. If the fretwork is true there is no magic cure for buzz.
Rich is offline
post #4 of 12 (permalink) Old 09-19-2011, 07:41 PM
Regardless of what anyone says, you learn by trying. There is no magic behind it but it does take time and practice. I commend you for having the balls to try!
Musician78 is offline
post #5 of 12 (permalink) Old 09-19-2011, 09:44 PM
CosmicDebris's Avatar
I don't normally give advice anymore but make sure your pickups are not too close to the strings. It won't cause "buzz" but will not give a clean sound if they are too close.
I have helped folks locally that thought they had bad frets and they just had the pickups too close the strings.
CosmicDebris is offline
post #6 of 12 (permalink) Old 09-19-2011, 09:51 PM
Reviews: 4
Does the note rings after buzzing? If i does, it's not really buzzing.
faekildare is offline
post #7 of 12 (permalink) Old 09-20-2011, 03:14 AM Thread Starter
Its sounds just like the truss rodd doesn't have enough relief but no matter how much relief I give it it doesnt go away. Its frustrating, I realistic about my action but its not working. Ive dressed the frets on my fender and an old epiphone 12 string acoustic and they came out great cant figure this Ibanez out.
JBOrocks is offline
post #8 of 12 (permalink) Old 09-20-2011, 03:23 AM
Fret the first and the last fret and look at the gap at the 9th. How much relief does it have?
Rich is offline
post #9 of 12 (permalink) Old 09-29-2011, 02:00 AM
A bottle of Jack Daniels and a baseball bat once fixed my fret buzz. Sometimes a guitar is just not meant to be.
Chompers777 is offline
post #10 of 12 (permalink) Old 09-29-2011, 07:01 AM
It's funny that you mention strings here, Rich. I have read a lot of people saying that Ernie Ball Slinky strings tend to buzz a lot, is this true?
aliendough is offline
post #11 of 12 (permalink) Old 09-29-2011, 11:27 AM
The easier a string feels to bend the more it will probably buzz.
Rich is offline
post #12 of 12 (permalink) Old 09-30-2011, 01:44 PM
I use Ernie Ball's and they buzz no more than the D'Addario's I used for years on the same guitar(s). (They sound a little brighter to my ears is all)
I do believe they are a little softer, so if you tend to leave your strings on for very long periods they will develop indents where they meet the frets and will eventually start buzzing, but all strings will do this, it's just that the Ernie Ball's will wear out a little faster... but again, I've not noticed any problems compared to the D'Addario's... but I change strings frequently too...
MicJustMic is offline
fret buzz
Got a new guitar, but its got fret buzz on one string at one fret how to fix? ibanezcollector Tech: Setup, Repairs and Mods 6 11-25-2006 07:43 PM
Fret buzz on 13th fret AleTheNervo Tech: Setup, Repairs and Mods 1 04-19-2006 08:49 PM
fret buzz - above 12th fret nat1201 Tech: Setup, Repairs and Mods 6 04-11-2002 01:29 AM
advice needed for strange fret-buzz on my UVGR - nasty buzz Superuser Tech: Setup, Repairs and Mods 8 02-19-2002 05:35 AM
Strange fret buzz - Only at 16th fret, G string carlos seo Tech: Setup, Repairs and Mods 3 02-07-2001 12:12 AM
