upper frets buzzing - Jemsite
post #1 of 16 (permalink) Old 04-27-2004, 06:14 AM Thread Starter
upper frets buzzing
Hi! I've recently bought an Ibanez JEM 7vwh and I have a problem with the frets around 10 and up buzzing only on the g-string (and a slight buzz on the lower strings). Does anybody have a solution to this?
Thomas
ThomasBJ is offline
post #2 of 16 (permalink) Old 04-27-2004, 07:31 AM
i dont think it's a truss-rod issue. fret 10 zone it's too forward up on the fretboard for the truss-rod to solve the problem.
you better have a pro tech take a look. your fretboard may need a slight leveling or a "fall-away" leveling, at least.
nuno is offline
post #3 of 16 (permalink) Old 04-27-2004, 08:21 AM Thread Starter
Thanks! A levelling means that something is put between the neck and the body right? Doesn't the guitar loose some sustain from that?
Thomas
ThomasBJ is offline
post #4 of 16 (permalink) Old 04-27-2004, 08:47 AM
leveling means giving the frets' surface the same height. this way you will get rid of anything between point to point of the string (that would otherwise have it buzzing).
nuno is offline
post #5 of 16 (permalink) Old 04-27-2004, 12:26 PM
If it has the EP bridge it could be as simple as that saddle is just too low.
Rich is offline
post #6 of 16 (permalink) Old 04-28-2004, 03:29 AM Thread Starter
Hi again! It has the Edge Pro bridge and I have tried to raise it a bit but it doesn't seem to get rid of the last buzzing unless I raise it a lot. How much should the action be (around)? I'm used to play a s540 FM in wich I have 6105 frets installed - but this guitar seems to have lower action and better playability. Perhaps it is a question about getting it broken in? I just bought it new last week and maybe I've forgot how it is to have a new guitar...
ThomasBJ is offline
post #7 of 16 (permalink) Old 04-28-2004, 10:49 AM
you should check for neck straightness, if it's straight or with a tiny bit of relief, then it's a fret leveling issue IMO.
btw: have you changed strings?
nuno is offline
post #8 of 16 (permalink) Old 04-29-2004, 05:13 AM Thread Starter
No I haven't changed the strings but I can see that it has D'addario 009's on and that is the same as I use. I think I will play it for about a month or so and then see how it works. Maybe I just have to get used to it. But is it normal that it is a little hard to play on the upper fretboard? I mean that it's not like the notes pop out of the guitar like on my Gibson Nighthawk.
ThomasBJ is offline
post #9 of 16 (permalink) Old 04-29-2004, 07:03 AM
i'd wait to see what will happen once you got a fresh set of strings, things can change alot with new strings.
nuno is offline
post #10 of 16 (permalink) Old 04-29-2004, 09:27 AM
I tend to think your action is too low for how much relief the neck has. You said you've raised it but to how high now? Too much relief with low action will choke out the second half of the scale.
Rich is offline
post #11 of 16 (permalink) Old 04-30-2004, 06:10 AM Thread Starter
The neck is actually straight as a line. (almost) So I don't think it's beacause of the neck. But the more I play the guitar the less buzz it seems to have. Maybe it's just beacause I'm not used to having a new guitar...
ThomasBJ is offline
post #12 of 16 (permalink) Old 04-30-2004, 08:23 AM
fresh strings affect either lack or presence of buzzing more than you can think.
nuno is offline
post #13 of 16 (permalink) Old 05-05-2004, 08:20 AM
A used RG I recently bought has a very pronounced buzz and lack of sustain at the first fret, especially the E and B strings. Is this something I can fix myself with some files and sandpaper, or am I gunna have to find a tech? Anyone have any advice on how I can fix it myself? Could it be something as simple as the top lock being too low?
Petie is offline
post #14 of 16 (permalink) Old 05-05-2004, 08:39 AM
it would make buzz unfretted strings only, not fretted ones.
anyway, i would give the truss-rod a quarter to half turn counter-clockwise, or i'd try raising the trem a bit.
nuno is offline
post #15 of 16 (permalink) Old 05-05-2004, 08:48 AM
Thanks nuno. I just tried raising the bridge and it definitely has a positive effect, but alas now the strings are a bit too high for my style (sounds great though, and feels very resonant). I don't have a truss rod tool at the moment so I'll pick one up on payday and cross my fingers. (Just put a deposit on a Yamaha DG130HA head, so I'm living on toast for a few days *LOL*)
Petie is offline
edge pro bridge , fret level , fret leveling , ibanez jem , lower strings , truss rod , upper fret
Jem7V tone problems near upper frets. amahran Pickups & wiring 24 05-12-2013 02:48 PM
2 frets buzzing arghhh Speedabob Tech: Setup, Repairs and Mods 12 02-05-2012 09:20 PM
Buzzing from 12 to 21 frets on Ibanez RG550 faekildare Tech: Setup, Repairs and Mods 19 06-18-2011 09:36 PM
Buzzing/Choking on only a few frets? Mattww Ibanez JEM, UV, JS & Other Signature Models 12 09-10-2007 03:54 AM
Buzzing on frets 7 and 14? twooos All Other Guitars (including Prestige) 25 06-26-2007 08:09 PM
